Guess I will have to use RoadRunner
I like centrafuse better but I just cant use it like this.
My volume level maxes out at 52% on the centrafuse volume gauge and then goes back down to 0db when it his 53% then proceeds to get louder all the way to 100%...
Anyone know why?
Does it happen when you hook up a mouse?
Scion tC 2005 with DWW-700H
Via Eden M10000, 512MB, 100GB 5400rpm, Xp Pro
It does. It seems that the link between the centrafuse mixer and the actual sound cards mixer arent in sync with each other.
If i bring up centrafuses' mixer panel, "front" is what is being controlled when i push volume up or volume down buttons on the main centrafuse panel.
This is the slider that gives me the trouble.
When I slide the other slider up and down, the far left slider (master?) i forget the name of it and im not in the car to see it, but when i slide that slider up or down, everything works great as far as controlling the volume.
If somehow I could map the volume up and down buttons to control that slider then it would solve my problem. Is this possible?
1997 Saturn SL2 Car PC Status [..........] 0% Complete (Removed)
1999 Honda Accord Car PC Status [::::::::..] 80% Complete (Setting up software before final install)
Also I just noticed that the volume doesnt go below 30% on the Percent Guage...
Have you got a VIA EPIA motherboard? I had the same problem using the 'latest' drivers from VIA.
Try downloading the real latest drivers from the VIAArena website. Think the lastest is 6.2
Having troubles getting to VIAArena at the mo so try here:
http://drivers.softpedia.com/get/SOU...ver-620M.shtml
Well as much as i liked centrafuse i've switched to roadrunner. Its not as good or stable IMO but i can turn it up and down, and it seems to be alot more active and not to mention open source... At least until there is an option to map the volume controls like there is in roadrunner!![]()
