Results 1 to 8 of 8
Thread: Controlling different volume slider with main volume control?
    Constant Bitrate noreason's Avatar
    Jan 2006
    Texas!
    I would like to control the "Pre" Mixer slider instead of the "Front" Mixer slider with the Volume ^ up and Volume V down buttons.
    Is there a way to do this? A setting i missed? Adjust the skin? Via the SDK?
    1997 Saturn SL2 Car PC Status [..........] 0% Complete (Removed)
    1999 Honda Accord Car PC Status [::::::::..] 80% Complete (Setting up software before final install)
    Variable Bitrate mercury7's Avatar
    Jul 2005
    Dallas
    I need to do this as well. David?
    2002 Grand Am progress :
    [••••••••••••••••………] - 80%
    ...complete setup, but still need to make the install cleaner
    FLAC alti's Avatar
    NY
    ditto.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    Jul 2005
    Dallas
    BUMP.
    The reason I need it is because the volume control stays stuck on a value, 50 or 70 something percent, and doesn't budge when I press up or down. However, I can go to the Mixer, and the "Pre" slider works fine for volume control.
    So, David, next release, or is there already a way to adjust the Pre levels?
    Jan 2006
    Texas!
    exactly my problems mercury but on one pc it stays stuck at 30% and on the pc i'm using the volume starts at 20% and maxes out at 54% and when it hits 55% the volume level starts over from 0db until it hits 100% again. Very annoying because i cant turn it down all the way so i have to use mute alot!
    I dont understand why it wasnt an option alreay since its a sure fire way to make centrafuse compatible with all sound cards that work in windows since it just uses windows master volume... oh well.
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by noreason
    do you have an error.log file? the percent you are seeing is nothing to go by, it's inaccurate and was a calculation problem which has been fixed... Also comparing to windows mixer will do you no good because I use logorithimic volume instead of linear, because that's how human ears work...
    if the sound isn't properly changing then their should be some sort of error that might help lend to me fixing the problem...
    david
    Jul 2005
    Dallas
    I cleared my error.log file because it was gigantic.
    Then I fired up Centrafuse and tried to change the volume. It would not change, and stayed stuck at 30%.
    This is the only error that was produced after I closed Centrafuse:
    PHP Code:
    2/20/2006 3:33:14 PM
    Exception from HRESULT
    0x80045006.
    at SpeechLib.ISpeechRecoGrammar.CmdSetRuleIdState(Int32 RuleIdSpeechRuleState State)
    at centrafuse.main.InitializeSpeechRecognition()
    Low Bitrate tC_install's Avatar
    Nov 2005
    Hollywood
    Turn yer speech recognition off. Clear error.log file and re-test again.
    Scion tC 2005 with DWW-700H
    Via Eden M10000, 512MB, 100GB 5400rpm, Xp Pro
  1. volume control
    By JaxPt in forum Car Audio
    Last Post: 03-04-2008, 09:07 AM
  2. Set Volume control to winamp instead of master
    By Ne-o in forum Road Runner
    Last Post: 01-01-2006, 07:20 PM
  3. Adjusting Wave & Main Volume Options??
    By xtreme_db in forum FrodoPlayer
    Last Post: 09-03-2004, 10:02 PM
  4. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-04-2003, 12:00 AM
