Hi,
I have installed centra fuse, then I select the music folder to my music folder, go into rebuild library, it scans all the songs, I can see them flash and stuff, and then it just says imported o songs and I can't play anything.
Someone please help
B Smoov
Project Status: 90% Complete
Next Step: TIVO for Radio
Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
Same problem here, and i have all drivers installed, and can play mp3 on WMP... any ideas??
EDIT:
I dont see tham flash and stuff it just doesnt find them. And my folder is ok, since 1.6 lets you browse to fing the folder.. Aparently centrafuse thinks my directory is invalid, since the video section of the ML shows my folder, but i get the "directory is invalid" message. My OS is in spanish, maybe there's the problem
Edit #2:
Alright i have worked this throug. What i did was to edit the config.xml, because apparently 1.6's file doesnt support accented characters, and substitutes them for a code equivalent to the accented char. So i copied an old CF 1.5 config file, and copied/pasted the entire content of the 1.6 file, then edited the MUSICPATH and videopath for this:
<APPCONFIG>
<VIDEOEXT>avi|qt|mov|mpg|mpeg|m1v|wmv|bin</VIDEOEXT>
<APPLANG>English</APPLANG>
<MUSICPATH>C:\Documents and Settings\Gilberto\Mis documentos\Mi música</MUSICPATH>
<VIDEOPATH>C:\Documents and Settings\Gilberto\Mis documentos\Mis vídeos\</VIDEOPATH>
<PICTUREPATH>
I had to but an extra slash at the end of the videopath, since i kept getting the invalñid directory error. However when i go to the video section in media library, my first selection (which should be "mis vídeos") is blank.
El Volcho is in progress... Got almost everything
-Via EPIA M10000, Super 7'' Touchscreen, Morex Cubid 3677 Case, Fujitsu 40Gb, 512DDR RAM, Sony DVD-CDRW...
Planning 80%
Parts 60%
Building 40%
Good catch.. File a bug under the Bug Reports section.
B Smoov
