Results 1 to 7 of 7
Thread: CF 1.5 has just started bombing to the desktop during loading
    Lum
    Lum is offline
    Variable Bitrate Lum's Avatar
    Jan 2005
    Liverpool, England
    It gets as far as "Initialising..." then just terminates, dropping me back to the desktop with no error message.
    I have uninstalled, reinstalled, uninstalled again, deleted the entire FluxMedia directory, reinstalled, re-applied the new licence file from january, no change.
    Any ideas?
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by Lum
    Any ideas?
    anything in your error.log file?
    david
    Lum
    Lum is offline
    Jan 2005
    Liverpool, England
    It has not created an error.log file
    I remember that being there before I uninstalled and nuked it (it only had old stuff) but it hasn't come back.
    Low Bitrate spiffywilco's Avatar
    Jan 2006
    On the smoothest of tarmac
    I had this problem at one point when I was first building my system. I wiped the .net framework and centrafuse, and then reinstalled them both. After that it worked fine. It was for me anyway, something with the .net framework.
    Instructions on removing .net framework:
    Start -> Control Panel -> Add remove programs -> .Net Framework 1.1 (or 2.0 whatever you have)
    Instructions on reinstalling it (easiest way)
    Microsoft .net Framework 1.1 Redistributable Package (I hate the windoze automatic installs)
    Go to http://www.microsoft.com/downloads/d...displaylang=en
    Or google "microsoft .net framework"
    Carputer Status: Half-Way There....
    On the list:
    Accele 8" Touchscreen, Viper 5000, Accelevision 6-in/6-Out Video Switcher, Shuttle 51G (donated) P4, 512mb, 320GB, Centrafuse 1.6!
    V.le Raffaello Sanzio... ahh Firenze!
    Lum
    Lum is offline
    Jan 2005
    Liverpool, England
    Thank you. Reinstalling .net 1.1 solved the problem.
    Edit: Apart from now the start menu appears on top of CentraFuse for some reason and I can't get rid of it
    Edit2: For some reason changing it to 852x480 (my actual screen res) instead of 848x480 fixed this. Weird.
    Low Bitrate keyvan's Avatar
    Dec 2005
    Orange County, CA
    I am having the same problem... except that nothing is helping. I uninstalled dot net and CF. nothing works to solve it. is it supposed to act this way maybe when the license ends on it? Because the comp has been lying around for more than 2 weeks or so while i waited for some new hardware and built my new homemade case and installed..
    Lum
    Lum is offline
    Jan 2005
    Liverpool, England
    There was a licence expiry at the end of last year, so providing you have fixed that one and the system was working in January, I don't think that would be the problem.
    I've just been out for a drive and my CF is still working fine with mine, and I'm pretty sure the date is correct.
  1. HD44780 LCD problem in cf 1.5
    By AngryMan in forum Centrafuse
    Last Post: 05-09-2006, 12:22 PM
  2. Replies: 11
    Last Post: 11-03-2005, 12:14 AM
  3. CF website showing signs of 1.5!
    By justintime in forum Centrafuse
    Last Post: 10-22-2005, 06:49 PM
  4. Warning... crazies ahead.
    By ddt in forum Off Topic
    Last Post: 05-12-2004, 12:06 AM
