Just embed iGuidance as an external app. This is what I've been doing and it works great.
Hello all,
My carputer has its OS loaded and I am just waiting to load Centrafuse 1.6 as my front end to start out with. I will most likely try RR as well just to see what I like about each. Any issues having two front ends loaded at the same time. I assume I need to set up some sort of option to decide which one to boot up in. Wouldn't mind help here either.
Anyway, I already have Iguidance ready to install, but am holding off since it looks like Centrafuse uses Destinator only. Is there any way I can use Iguidance and centrafuse together? I am not opposed to destinator since I have not even used Iguidance yet and have no prior experience. I would just like to use what I have at least in the beginning and then maybe get Destinator down the road once Centrafuse supports the latest version.
Best regards,
Marc
Can you have a button in Centrafuse send a command to iGuidance?
