Please post such errors in the PhoneControl Forum and please apply the version of the BT-Driver you're currently running.Quote:
Originally Posted by Lum
Printable View
Ok, is there some way to actually check to see if the XM is working? I set the XM up in the setup. Then when I go into the XM mode it just sits there and never gives me any audio. If I exit and go into my other software the XM comes right up. Just curious as if there was some other setting I needed to change.
Just need to set the device and comport and make sure the other application is closed. Which device? I only tested with the XMPCR because it is the device that I have. I code for the XMDIRECT, but there might be some bugs in the init code because I did not have a unit to test with before this release...Quote:
Originally Posted by jcdillin
david
Oh sorry, yeah it's a XMDirect and the other app is for sure closed
check to see if there is anything in your error.logQuote:
david
