I get the following error during pairing with both of my Bluetooth phones
Code:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at BTSTACKSERVERLib.BTGAPApiClass.GAPBond(Object bda, Int32 pin_code_len, Object pin_code, Int32 trusted_mask)
at zBTHelper.BTHelper.Bond(BTDevice pi_oDevice, String pi_sCode, Int32 pi_iTrusted)
at PhoneCtlWizard.Form1.PairDevice()
at PhoneCtlWizard.Form1.btnNum_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
PhoneCtlWizard
Assembly Version: 1.5.0.14728
Win32 Version: 1.5.0.14728
CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/PhoneCtlWizard.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
zBTHelper
Assembly Version: 1.0.2190.21340
Win32 Version: 1.0.2190.21340
CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/zBTHelper.DLL
Infragistics.Win.UltraWinTabControl.v3.1
Assembly Version: 3.1.20041.15
Win32 Version: 3.1.20041.15
CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/Infragistics.Win.UltraWinTabControl.v3.1.DLL
Infragistics.Shared.v3.1
CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/Infragistics.Shared.v3.1.DLL
Infragistics.Win.v3.1
CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/Infragistics.Win.v3.1.DLL
Infragistics.Win.Misc.v3.1
CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/Infragistics.Win.Misc.v3.1.DLL
OpenNETCF.Net.Bluetooth
Assembly Version: 1.4.50709.0
Win32 Version: 1.4.50709.0
CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/OpenNETCF.Net.Bluetooth.DLL
OpenNETCF.Desktop.Communication
Assembly Version: 2.8.2181.32655
Win32 Version: 2.8.2181.32655
CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/OpenNETCF.Desktop.Communication.DLL
Interop.BTSTACKSERVERLib
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/Interop.BTSTACKSERVERLib.DLL
Accessibility
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Also, there is no 852x480 resolution any more and the setup will not let me add it to that list
