Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: What TV and FM card and where are the RELEASE NOTES?
  1. #11
    Apr 2005
    Dublin, Ireland
    Tv Support
    Thanks,
    Ive put off buying a tv.fm radio card until i see how this works out, esp since the WINTv USB FM cost more than a PCI Low Profile WinTv PVR 150 with FM,
    Are those devices with Hardware Encoders easier for you to support than those like the BT8x8 chipset..
    P4 Celeron 2.2 - 512MB - OPUS 250 - Audigy SE - BU353 - HQCT - No Speakers though :-(
  2. #12
    Oct 2004
    hey david i have the wintv 150 pci card i got the tv portion to be recognized in CF but the radio portion does not see this card???
  3. #13
    Newbie Stompit's Avatar
    Dec 2006
    Melbourne, Vic, Australia
    Daaa
    For the love of god!! Would someone from CF please, oh please, list a couple of internal and/or external fm/tv cards that have been tried and tested with CF, I've been trawling the forum for aaages and its like pulling teeth!
    There must be units that have been tested and confirmed to work well with the current CF build.
    I promise not to throw a hissy fit if I do purchase and end up having problems, I just want someone with experience to point in the right direcion! Pleaaaase, I'll be your friend forever...
    Thanks Folks, oh and "Hello" this is my first post, consider my cherry well and truly popped.
    Dunc
  4. #14
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by Stompit View Post
    Dunc
    I personally tested it with the WinTV USB... It worked fine after I got the drivers setup right and telling it to send the audio through the USB line...
    david
  5. #15
    Dec 2006
    Thanks for the swift reply Veedit I am very impressed with the CF product by the way, especially the UI! Great stuff
    Sooo, what we are saying is that the FM radio and TV sections of the CF software should be able to accept input from this device:
    http://www.hauppauge.com/pages/products/data_usbfm.html
    And that it provides acceptable results while on the move.
    Seeing as you have experience with this device, would you have any pointers on what type of additional drivers would be available, or a quality antenna that provides good reception while on the move
    Again, many thanks for you help with this
  6. #16
    Dec 2006
    Anyone?
    P.S. Merry Christmas folks
  7. #17
    Oct 2004
    was wondering if this card would work with CF KWORLD VS-LTV883RF i never did get an answer on if the wintv 150 model will work later i get video to come up jumps around though i think its because i am testing it on an older pc that prob cant handle it, but cant get cf to recognize the radio even if Id o download that one program radiator.
    any help on what pci cards that will work that have both a tv tuner and a fm tuner both built on the same card???
  8. #18
    Dec 2006
    Looks like a winner
    I'm searching through the forums to see if anyone has any experience with this:
    Leadtek WinFast TV USB II Deluxe
    http://www.ccw.com.au/Products_Detai...TVU+++++PAR%3A
    But if anyone from CF would like to comment it would be most appreciated
    Ta
    Dunc
  9. #19
    Dec 2006
    Just found a quote on that Happulblageo thingo from Veetid:
    "TV will most likely not work at the same time you have Radiator loaded and locked onto the device...
    If you try to disable Radio, you will probably be able to get TV to work...
    I plan to look into a solution to use both at the same time, but it does not work as of now...
    david"
    I cant really be arsed trying to get two things to work from one device so I will probably go with the HQDT and a seperate analof TV tuner. Still researching TV tuners!!
    Ta
    Dunc
