Results 1 to 10 of 19
Thread: What TV and FM card and where are the RELEASE NOTES?
    FLAC mbkowns's Avatar
    Mar 2004
    SOCAL
    Which is the best USB TV card and fm card combo to use with centrafuse?
    I was hoping it was in the release notes.
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
    VENDOR - Centrafuse veetid's Avatar
    It should work with most WinTV cars/usb devices... It has some problems with the USB PVR model...
    The FM will only work with the 8x8 chipset based cards...
    david
    Mar 2004
    SOCAL
    any model you recommend? You say basicly all will work well if u were going to get one what do you think you would get?
    Apr 2005
    Dublin, Ireland
    WinTV USB FM
    This seems to be the best external option, although i am a bit hesitant about how my 1GHz P3 will handle the Software Encoding of the Tv Signal, on the plus side it doesnt require an external power source but it has recieved so so reviews, so say its excellient so say is rubbish, id sayy thats a lot to do with the arial through.
    P4 Celeron 2.2 - 512MB - OPUS 250 - Audigy SE - BU353 - HQCT - No Speakers though :-(
    Apr 2005
    Question Support for CX2388x cards
    Hi guys,
    I would like to know if is there some chance of running CX2388x cards at this moment. I am sure that many people has this chipset in their cards too.
    As we know, there are just a few chipsets that is present in the most nowadays TV cards (BT8x8, CX2388x, SA7...).
    By the way, which one is the chipset used in WinTV PVR?
    I don't think it would be too difficult creating a universal TV and radio WDM plugin by using DirectX SDK.
    David, how long we should expect to get it done?
    Thank you.
    Marco
    If it has an 8x8 chipset in it, it might work now...
    I will look into this card...
    david
    Aug 2004
    Black Hills, SD
    I found this little link that will probably be of some help to poeple.
    http://www.tvoon.de/support/cardlist...ermodelle.html
    The question I have is the Tv will only work for WinTV cards? Or will other TV/FM cards listed on this page also work?
    Hardware: VIA Epia MS 12000, 512 DDR, 60GB HD, 7" Xenarc, GM-210, Wi-Fi, Bluetooth, Radio Xtreme
    Software: Centrafuse2, Phonecontrol.net, nLite, TopoUSA 5.0, iGuidance, Girder, Winc
    Constant Bitrate HoSS's Avatar
    Dec 2004
    Is / Will the Xtronic FM module supported?
    http://www.xtronic.be/index.php?id=3&lang=2
    Dec 2004
    Bump
    @ David - Xtronic FM module support?
    Quote Originally Posted by HoSS
    Bump
    I plan to add support... Waiting a test unit to be mailed to me... I also have already taken a look at some of the source code...
    david
