Wow! history in the making. You released an update in less than 24 hours. KUDOS to FluxMedia!
I hope this is an indication of how things will progress from now on, as it relates to timely upgrades. Well done man, this is very re-assuring.
I have posted new 1.6 msi files. Everyone needs to uninstall 1.5 and 1.6... Then manually delete the Flux Media/Centrafuse folder...
This version fixes the serial number problem. Your 1.6 serial number from the website should now work...
I also set this new uploaded 1.6 to remove the directory during uninstall. So when the next release is posted it will be set it to uninstall the previous version and we shouldn't have the problem anymore of having to manually delete the directory...
Once I get a good list of bugs to fix I will release 1.61. In this version I will also make the installation of Destinator and PhoneControl optional during setup.
For now just close Centrafuse and move Phone from the plugins directory to the pluginsinactive directory, or delete it if you think you will never use it.
david
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
thanks! if you've already got it working do i still need to redownload it?..
my destinator map resource down permanently
You dont' have too... Basically I added the support for the 1.6 serials, there was a bug... I also added a method to delete the directory during uninstall... So when I release another version you won't have to delete your Flux Media/Centrafuse directory...Originally Posted by GReeToZ
Otherwise, you don't have too... just remember next release to manually delete that folder before you install it...
david
