Results 11 to 20 of 27
Thread: SKINbedder with 1.6 Problems...
  1. #11
    Variable Bitrate m2x0p9x's Avatar
    May 2002
    Modesto, CA
    So veetid are u willing to re-release this with the fix...i would go crazy if i had to wait for 1.7
  2. #12
    Raw Wave justintime's Avatar
    Apr 2005
    It would be awesome if we could get a hold of a Version of CF that has no major dealbreakers. Something along the lines of what CF 1.4 was.
    I know David won't less this happen, he will get it fixed asap -- cannot afford to have another 'unusable' version of CF out there for 4+ months until a new release. I don't think anyone in their right mind would continue with this eternal torture!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  3. #13
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by justintime
    you sure do have a lot of time on your hands to continue to post negative things... if you don't like Centrafuse, don't use it.. go use another frontend or write your own...
    note: your negative criticism doesn't help anyone... you have made it very clear in multiple posts what you wished was changed... it's been noted, thanks...
    david
  4. #14
    Quote Originally Posted by m2x0p9x
    I plan to wait another couple of days to get a good list of bugs and release 1.61 after I get them all fixed.. There will never be another long wait like there was for 1.6 because I am adding no more major features...
    It's all bug fixes, small feature enhancements, and support for more devices to lead towards a completly stable version...
    I will have to find a copy of IG because I don't have one and everything I embed works, then figure out what is causing the problem... I didn't change any of the embed code from 1.5 to 1.6, so I'm really not sure what is going on, but I will get it fixed...
    david
  5. #15
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by veetid
    you sure do have a lot of time on your hands to continue to post negative things... if you don't like Centrafuse, don't use it.. go use another frontend or right your own...
    david
    I hope you only joking.
    If you don't listen to negative comments, your product will NEVER improve.
    As a developer like yourself, I don't like negative comments form users, but they are one who use your app.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  6. #16
    Quote Originally Posted by MatrixPC
    I've been on these forums for quite a long time, listening and adding support for just about everything requested...
    constant negative criticism is not necessary and it's counter productive to state the obvious and re-post the changes you don't like over and over.. they have been noted...
    david
  7. #17
    Oct 2004
    Same problem with Map Monkey & Freedrive
    david
    Hi all!
    A good release david, things are coming along! Shame about the bugs but I don't think that was the point of this release. The feature set looks great so I look forward to the bug fixes! keep up the good work!
    Thought I'd add that exactly the same problem described in this thread is occurring with Map Monkey and FreeDrive when trying to embed them. I know they're destinator in various forms, but you don't have speed camera support yet
    Go download a copy and you should get the same results.
    Also along the same lines I think theres a bug somewhere to do with the resizing algorithm when dealing with Map Monkey/Freedrive/iGuidance. My resolution is 800x600 so the skin is resized from the default 848x480. When embedding any of the above 3 GPS programs as external apps around 30 pixels worth of the program is chopped off the bottom when in fullscreen mode. This occurred in 1.5 as well as this release of 1.6 (along with the above issue too)
    Hopefully you can replicate the above situation and find a fix. Good luck in squashing the bugs!
  8. #18
    Quote Originally Posted by cold_fusion
    Hi all!
    appreciate the support and I will get this embed issue figured out... it's on the top of my bug list...
    david
  9. #19
    Apr 2005
    Well, I am not going to take that comment personal. I might be repeptitive, and I might sound negative, but the 'free time I have on my hands' has been spent TRYING YOUR PRODUCT, and also attempting communicate to you how I think CentraFuse would succeed.
    Do you seriously think I would waste a minute of my time testing CF, and posting my thoughts, if I did not genuinely care about the future of the app? It is just not my style to spend time detailing all the good stuff about CF (which accounts for 80% of the app). I concentrate on the areas that I think can/should be improved. Sorry my comments are getting repeptitive and negative.
    Seems like you too are conentrating on the 'bad'... I want to believe I have done far more good towards the adoption of CF in this community than the 'negative' image that you noted. Numerous examples to be noted, but I am not going to rub them in anyone's face.
    I really want CF to be the best it can be. I agree I might not be doing the best job at it.
    2002 Honda CR-V
  10. #20
    I appreciate all your help testing and I have noted all the points you have made, and some are valid, but all noted to check into...
    again thanks for all the help testing and all your bugs have been noted and your opinions taken into considerations, as always...
    david
  1. [Release] SKINbedder V3 - Preview
    By RPM_VR4 in forum SkinBedder
    Last Post: 08-16-2008, 10:22 PM
  2. [Release] SKINbedder BETA 2.99999
    By 0l33l in forum SkinBedder
    Last Post: 09-23-2005, 04:38 AM
  3. [Release] SKINbedder v2
    Last Post: 07-05-2005, 05:01 AM
  4. DWW-700M/MTS12000 Motorized In Dash LCD Problems
    By techy101 in forum LCD/Display
    Last Post: 06-29-2005, 08:12 PM
  5. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
