Results 1 to 7 of 7
Thread: random actions set vol to 0?
    Feb 2004
    Seems like at odd points when I switch around in the menu, the volume gets tossed straight to zero.
    This is sort of irritating because the ever-popular log volume scale has to be pushed to 80% to get ANY sound out of it, and the volume buttons need to be tapped repeatedly (can't just hold it down, unless this is an issue with my touchscreen setup).
    Has anyone else had this "random muting" issue?
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by zerodb
    you should be able to hold the volume buttons down. make sure you have right click disabled on your touchscreen or it will not work. most touchscreen drivers have a hold for 5 seconds, right click option.
    Do you have voice enabled and a mic running?
    david
    Raw Wave tj!2k4's Avatar
    Oct 2004
    zerodb, maybe it caught wind of your mp3car username, and is therefore setting the volume level to 0 db...
    In all seriousness though, from my experience random muting occurs if speech recognition is turned on. For some reason it likes to interpret my music as "computer mute."
    Feb 2004
    Quote Originally Posted by tj!2k4
    No, I don't have any mic input active right now... but thanks for the heads up on that.
    I think it happened when I went into the setup menu and exited setup... maybe I just accidentally did somethine else I didn't realize.
    Feb 2004
    Quote Originally Posted by veetid
    I thought about that right after I posted this. I think that's what's going on.
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    I had a similar problem, fixed it by manual selecting NONE in the "line" section of each embedded app and plugin. seems that if you don't select it manually it won't remember the setting.. I had this issue with 1.5 too
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    Aug 2005
    yes i'm getting the same problem, happens when i re-enter the "media" section, it is really fustrating to have it drop back to zero, but other that the app is prefect in every way, think i'll switch from ME to CF now , it rules
    Update: yep Frankino method works, had to reselect "None" under "line" in the notepad external app to fix it.
    o anyone know how to change the double clicks, like browsing for music in "media" to a single click, its hard to doulbe click on a touch screen??
  1. Dual monitor set up and function?
    By dogger in forum Newbie
    Last Post: 10-09-2004, 08:58 PM
  2. Replies: 1
    Last Post: 06-18-2004, 06:49 AM
  3. need help with my set
    By CorollaVerso'04 in forum Newbie
    Last Post: 04-18-2004, 04:32 PM
  4. Random play on videos?
    By Magma in forum Media Engine
    Last Post: 04-01-2004, 03:21 AM
  5. LCD randomly changing set?
    By mad man in forum LCD/Display
    Last Post: 12-14-2003, 08:33 PM
