Results 1 to 10 of 12
Thread: How do you add songs to an exisiting playlist?
    May 2005
    Champaign IL
    I've never really used the playlist feature, but I did today. I added a few songs and saved it. I let it play and then I went to add a new song to it by click the + symbol then save and it asked if I wanted to overwrite the existing one.
    Can you add songs to an already created playlist or do you have to start a totally new one?
    Quick question about the photo viewer.
    I see that it utilizes the media library layout. When I click on photos it pulls up the approriate directory, I'm trying to figure out how to make them randomly slide? I see the slideshow button, but when I push it only shows one photo.
    Maximum Bitrate buurin's Avatar
    Sep 2005
    Seattle, WA
    I also would like to know about adding to a playlist..
    in 1.5 you could add a playlist to the queue then add songs to the queue and resave the queue as a playlist. you no longer can add a playlist to the queue
    B Smoov
    Project Status: 90% Complete
    Next Step: TIVO for Radio
    Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by Anointed
    highlight the entire folder and hit play now, this will load all your photo's into the list... I still have some work to do on the picture viewer...
    It was just making sure you wanted to overwrite... You essentially are starting over, but it works the same... You created a playlist, then added some more music, and resave as the same playlist name.... It will ask if you want to overwrite, but if you do it will update the playlist...
    david
    Jan 2005
    San Diego, CA
    So steps are:
    * Open existing playlist
    * Open Media Manager
    * Add Songs to media
    * Save over existing playlist
    ?? Is this how it should work? -- to lazy to run to my car and test it right now =P
    Quote Originally Posted by solodesignz
    So steps are:
    yes...
    david
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    David,
    did you like my idea for this process? or are you going to keep it this way?
    DICE Los Angeles
    Jun 2002
    Virginia
    David,
    But this means you are not adding songs to an existing playlist but are creating a new playlist from scratch each time? Am I correct about this?
    It would be nice if you could load an existing playlist to the queue, then add the additional songs you want in that playlist, then save.
    Quote Originally Posted by kbreeden
    David,
    That's exactly what you do... It just pops up a dialog making sure you want to overwrite... The save dialog is prepopulated with the current playlist and all you do is hit save and enter...
    I know it's a couple of extra clicks, but you shouldn't be building playlists while driving...
    david
    Jun 2002
    Virginia
    I wouldn't be building playlists while driving. It's just that some of us take a quite a bit of time building playlists. If, for example, I wanted to build a playlist called "Beach Music" I would have to add music from many different places. It would probably take a half an hour or more for me to populate the playlist. If I then wanted to add a couple of songs at a later date, I'd have to rebuild the whole playlist again.
    no you don't... simply load the playlist by clicking on it and hitting play now... If you decide you want to add some music too it, click music manager again, add whatever music you want, and hit save... click ok to overwrite... it will have all the old music and the new stuff you added...
    david
  1. iTunes Playlist Converter
    By konnichiwa in forum Centrafuse
    Last Post: 11-27-2008, 04:29 PM
  2. Audio CD Auto-play Playlist NOT updated
    By layanto in forum RR Bug Tracker
    Last Post: 01-03-2006, 04:40 PM
  3. playlist necessary? (philosophical)
    By crippy in forum Software & Software Development
    Last Post: 10-16-2003, 03:39 PM
  4. Replies: 3
    Last Post: 12-28-2002, 11:47 AM
  5. Winamp playlist order help
    By Zonma in forum Software & Software Development
    Last Post: 01-11-2001, 08:25 PM
