Results 11 to 20 of 22
Thread: Differences between 1.5 & 1.6, Tags
  1. #11
    Constant Bitrate lifeboat's Avatar
    Nov 2001
    Oregon Coast
    Not sure what the problem is, I just checked my tags and they are v1 and read correctly by Godfather...
    IEI PSB-4710, 1.5Ghz P4, 1GB RAM, 120GB HDD, Lilliput 8" TS, M2-ATX, BU-353,
    Ikey SL75 keyboard, BT Mini Keyboard, WLAN, EVDO, IC-PCR100 (AM/FM/VHF), HQCT, Centrafuse 1.6...
  2. #12
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by lifeboat
    I have some improved tag reading code in the upcoming release, hopefully it will fix your problem...
    david
  3. #13
    Nov 2001
    Oregon Coast
    I retagged one more time with APEv2 using T&R, all is well now.
  4. #14
    Sep 2005
    You have to use ID3 Tag v2.3
  5. #15
    Nov 2001
    Oregon Coast
    Most of my files are MPC format, the standard tag for MPC is APE. It's working fine now, but I had to strip all the tags and redo them from a filename mask first. CF is fussy with tags, they have to be just right it seems.
  6. #16
    There are some tag improvements coming in 1.7....
    I found a few bugs....
    david
  7. #17
    Jun 2006
    Akld New Zealand
    I'm having the same problem with FLAC - the genre, artist etc is being read for some files but most are just going under unknown artist - I cannot find a difference between the files that are read and those that are not. I assume something is not quite right when the database is built.
    Like the application - handles flac and nice genre - artist - album heirachy.
  8. #18
    Feb 2006
    All of my mp3 showed up correctly until today. I told it to rebuild my library because i added some music to my collection and now every single file comes up as "unknown artist - filename".
    I have tried removing both 1d3 ver 1 and 2 independantly of each other. I compleetly removed them both and started from scratch with them. Everything i do gives me the same thing "Unknown Artist - File name" every single file.
    I just dont get it they were all showing up correclty before and i did not change a thing about them, all did was click rebuild my library to add in my new music and then this whole **** storm happened!
    HELP!!!
  9. #19
    Check your error.log file and sent it over or post relevant part so I can see what happened...
    david
  10. #20
    Sep 2005
    Bay Area, CA
    Centrafuse 1.6 displays absolutely no tag info from any of my flac files. I tagged them using TagScanner (latest rev) and tried every variety of tag supported. I browse directly to the files using Music Paths, so it isn't an issue with library building. And there is no error.log to be found in my Centrafuse directory.
  1. is there a list of changes from 1.5 ---> 1.6 ??
    By bishooman in forum Centrafuse
    Last Post: 01-23-2006, 03:49 PM
  2. is there a list of changes from 1.5 ---> 1.6 ??
    Last Post: 01-23-2006, 06:42 AM
  3. Replies: 11
    Last Post: 11-03-2005, 12:14 AM
  4. 4am MUSIC Console 1.6 (HDD Jukebox Software)
    By OvernightTech in forum Software & Software Development
    Last Post: 01-03-2004, 01:02 AM
  5. voice for ID3 tags
    By mp3designer in forum General MP3Car Discussion
    Last Post: 06-23-2001, 11:32 AM
