Anyone have these problems? the volume is driving me nuts!
I had this same problem in 1.5 and so i assumed it was a bug...however it appears to be back again in 1.6.
1. volume control - the volume drops down to 0% on a random basis. It seems to happen whenever NAV gives voice directions...
which brings me to my second problem.
2. the voice prompts for nav are not audible? The music pauses (drops the volume down) and i don't hear a thing.
Anyone have any suggestions?
Asus Pundit Barebones PC
7" Lilliput LCD
P4 2.8ghz 512mb 120gb
Windows XP Pro, VOICES
Sony Xplode 10in Sub, Rockford 600w amp
Pioneer 6x9's and 4x6's, Kenwood 4ch amp
Black Widow Alarm with Pager
7" Lilliput LCD
Not I. But I use iguidance. whats your error.log file say?
Scion tC 2005 with DWW-700H
Via Eden M10000, 512MB, 100GB 5400rpm, Xp Pro
I haven't checked, didn't know it existed.
What about the volume issue? It randomly drops to 0.
7" Lilliput LCD
Open up your error.log file in notepad. (Its in the Centrafuse install directory). Select all, Delete, Save.
RE-create the volume problem (you might want to also post the steps to reproduce here). Close CF, re-open the error.log file and see whats breakin.
I will do that tonight.
As for recreating it...i really don't have to do anything to recreate it...it happens every few minutes. i really don't have a special config in any way either.
Also i should note, when CF first launches...vol is dropped to 0, every time.
The volume for REAR/SUB doesn't work either in the EQ section of the program. Only the one slider works. I'm using KXX drivers on an audigy.
Thanks for your replies.
7" Lilliput LCD
remember to manually select NONE in the volume control section of EACH embedded apps and plugin.. works for me
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
each plugin? i didn't know there was a volume section...i'll check into that though
7" Lilliput LCD
