Results 1 to 10 of 10
Thread: CF 1.6 shows protected system files !!
    Variable Bitrate bishooman's Avatar
    Jan 2006
    Kuwait
    CF 1.6 shows protected system files like system voluem information and media player it is also show the hiddin jpg's and ini's used as a cover art
    this should be fixed\thanks
    We Exist because there is no patch for human Stupidity !!
    We need you ALL Here !!
    VENDOR - Centrafuse veetid's Avatar
    Where? In the file browser where you select music paths?
    david
    Elsewhere
    That's a Windows Folder Options setting...
    I don't use CF (although I might start!)m but I don't believe an application can override that.
    How about the Wiki?
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    Quote Originally Posted by veetid
    david
    yes
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    Jan 2006
    Kuwait
    david
    David for me it appears every where when i play mp3 files it shows the hiddin jpg file in the list when i add music paths or any thing that has a list with browsing option !!
    by the way i have the opption hide protected system files (Recommended) enabled
    Bashar
    Quote Originally Posted by bishooman
    Bashar
    under media manger their is a bug when browsing by music paths which makes it show the images, hidden or not... this will be fixed...
    david
    Jan 2006
    Kuwait
    david
    this is one of them
    it is in media player also
    it is in settings when i set the music and video and photo paths
    i will tell you if i fint it anywhere else
    by the way did you tried the MAP ??
    this is one of them
    You see files when you set the music/video/picture paths? You should only see folders...
    That map should work fine...
    david
    Jan 2006
    Kuwait
    david
    no i dont see files here only the folder "System Voluem Information"
    good news about the map so it will work with D6 thanks for your help
  1. New EWF + MinLogon and CF instructions
    By SFiorito in forum WinNT Based
    Last Post: 03-12-2010, 01:39 PM
  2. Replies: 12
    Last Post: 03-16-2009, 07:00 PM
  3. Replies: 85
    Last Post: 07-09-2007, 04:44 AM
  4. XP System Builder
    Last Post: 03-19-2007, 05:13 AM
  5. my mp3s are turned into system files
    By [email protected] in forum General Hardware Discussion
    Last Post: 08-10-2001, 10:07 PM
