Results 11 to 20 of 27
Thread: Invalid License!?
  1. #11
    Constant Bitrate mnapoles's Avatar
    Feb 2006
    Miami, Florida
    I did delete the folder and still had the same issue? i tried it about 5 different ways on my lunch break today and everytime i had the same issue on re-installation
    perhaps renaming that file and then running the program and putting the key will work...
    2003 Honda Accord EXL-V6
    *MY INSTALL THREAD*
  2. #12
    Constant Bitrate djchicago's Avatar
    Chicago Ill
    hope u didi not update ur net framework to 2.0, if so remove this version, uninstall CF remove all key in the reg and restart, then reintall, this is what I did to get it working
  3. #13
    Feb 2006
    Miami, Florida
    nope tried to find that file to rename it and its not there?! so far i have been using media player and mobile impact but i miss my centrafuse any OTHER ideas?
    *MY INSTALL THREAD*
  4. #14
    Oct 2004
    NY
    FORMAT C:\
    jk
  5. #15
    Constant Bitrate TyBong's Avatar
    May 2005
    Rhinelander, Wi
    "You have insufficient privileges to access directory 'C:\Windows\Assembly\GAC\Xheo_Licensing'"
    sounds like your admin at work locked out your computer or "limited user" Ive had this error before on client's machines before, use an admin account it should work Im alittle drunk so if this does not make sense, blame the alchy
    Quote Originally Posted by turbocad6
    FORMAT C:\
    jk
    alittle extreeme but it would work DO IT hehe
    MORE COWBELL.
  6. #16
    Feb 2006
    Miami, Florida
    Angry
    Sorry if the humor was lost in translation but I'm sure the frustration wouldnt if it was your frontend that wasnt loading properly.
    I have tried all the solutions here with the exception of the "format c:\" which is a poorly written command anyhow.
    None of them have worked and it keeps prompting me "Invalid License" so i suppose i will continue to use Mobile Impact until theres a fix or until the previously mentioned 1.7 comes out which will fix the problem automatically?
    *MY INSTALL THREAD*
  7. #17
    Oct 2004
    NY
    it was a joke...,jk= just kidding.... believe me I know the frustration of licence issues in cf....any luck with the registry?
    I wish I knew a solution to your problem......
  8. #18
    Feb 2006
    Miami, Florida
    Its cool im just getting really aggravated.
    I tried the registry, i tried uninstalling then removing the Flux Media folder, i tried manually uninstalling everything, i tried renaming the file but couldnt find it even with "show hidden files and folders" enabled, i tried everything short of "format c:\" which i know WOULD work but i dont have the time or the desire because there are many front ends. i just liked centrafuse the most but im getting used to mobile impact and its not that bad.
    Oh well like i said unless david has any ideas i will just wait till 1.7?
    *MY INSTALL THREAD*
  9. #19
    Oct 2004
    NY
    did you try a search for "licences" in all files & folders?
  10. #20
    Feb 2006
    Miami, Florida
    Yeah i tried searching all files and folder as well as searching the registry for anything that would have to do with licenses or centrafuse? if david was looking for a good way to prevent people from finding the license file...
    MISSION ACCOMPLISHED! i have gotten rid of viruses easier than this!
    *MY INSTALL THREAD*
  1. Phoco license problem
    By tbird7 in forum PhoneControl
    Last Post: 02-16-2006, 01:43 PM
  2. License invalid after messing with date
    By Will Albers in forum Centrafuse
    Last Post: 09-28-2005, 10:35 AM
  3. MSDXM.OCX - Why oh why don't you fix that NOW?!
    By Zippy1970 in forum Media Engine
    Last Post: 02-28-2005, 04:36 PM
  4. cant change skins???
    By Hell-Stopper in forum FrodoPlayer
    Last Post: 11-05-2004, 10:10 PM
  5. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 12:25 AM
