Results 1 to 10 of 13
Thread: What is the best Destinator maps to use?
    Variable Bitrate bns2000's Avatar
    Nov 2004
    Russellville, AR
    What are the best Destinator maps to use with Centrafuse 1.6
    CENTRAFUSE From Flux Media
    The Ultimate Infotainment Interface
    Download V1.20 from there site now!!!!
    Download the new 2.0 RC1 From here Linky
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    depends where you live
    PC Components:
    My work log
    Nov 2004
    Russellville, AR
    in the us in arkansas
    I mean witch version of destinator maps do i use
    Newbie Thann's Avatar
    Jun 2005
    New Orleans, baby!
    If you're looking to just see how it works, I'd say you probably want to wait until CF1.7 comes out. David said in another thread that 1.7 will use the new engine.
    Ride: 2004 Nissan Murano SL AWD/Sheer Silver/Black Leather/factory HIDs.
    MoPuter: Transflectivized Lilli 7", EPIA M-10000, 512Mb RAM, 160Gb WD, SBLive!, 54g WLAN, Holux GM-213, 160W M2-ATX PSU
    Nov 2004
    Russellville, AR
    well what engine is it currently using
    Mar 2006
    Destinator 3 wich is from 2003...
    1.7 will use Destinator PN wich is from 2005.
    1.7 is promised later this month.
    I'm using PN maps, but they have to be modified to be used with CF 1.6.
    No new features from PN work on these maps.
    Nov 2004
    Russellville, AR
    how did you modify them to work with centrafuse
    Lum
    Lum is offline
    Variable Bitrate Lum's Avatar
    Jan 2005
    Liverpool, England
    You need to delete the files WCE_B1.dat and WCE_B2.dat (not sure if .dat is the right extenstion, but the names are definately correct)
    You may also have to rebuild the maps using the Map Cutter application provided with destinator PN (didn't seem to make a difference to me)
    I also find that when routing, certain junctions cause CF to bomb to the desktop. This is a little less likely to happen if you mute the audio and alot less likely to happen if you have another screen selected in CF and rely on the voice prompts (audio not muted, obviously)
    It's annoying, but doesn't happen so often that it becomes unuseable. Just remember to store your destination as a favourite so it's quicker to re-calculate the route when you reload after a crash.
    It seems to be mainly roundabouts that cause these crashes, and since you're in the USA which generally doesn't have roundabouts, you may find it runs a lot better.
    1.7 with the PN engine should sort this problem out and not need those files deleting.
    Mar 2006
    You need to delete the files WCE_B1.dat and WCE_B2.dat and include the WCE.TXT from the CD, then cut the maps in Mapmonkey. Just cut something... And save, then the map will be saved in a Destinator 3 compatible format. I've had no problems with PN maps.
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Don't you still need a cracked dest.dll in order to get Freedrive/Mapmonkey/CF to work?
    Also, are the maps from PN better looking than the old D3 ones or something? ...or are people just using PN maps for the small number of road changes from 2003-to-2005?
