Results 1 to 9 of 9
Thread: Auto pause upon hibernate?
    Nov 2004
    I have a remote start in my car, so when I initially startup the car and carputer, I don't want any music playing. Is there a way to have centrafuse pause whatever is playing so that when I resume from hibernation all that I have to do is hit the play button?
    Sep 2005
    North Carolina USA
    Centrafuse has a "action on hibernate/resume/standby, etc." function.
    You'll find it in the Settings.
    This seems to be geared towards running a program on hibernate/resume, however it would easily run some sort of script.
    There is a program called Autohotkey that can do all kinds of stuff in script form, (sending a pause keyboard shortcut would be easy).
    You can even compile the Autohotkey script into a standalone EXE.
    I can't recall the CF shortcut for Pause right now, otherwise I'd whip it up for you, myself.
    Once I can get back in my car and see what that shortcut is, I'll post you a solution.
    -Paul
    Jun 2005
    Funny. Mine seems to autopause each time its turned on. It seems to do this because destinator is saying "gps not found"
    Sep 2005
    North Carolina USA
    Thumbs up
    Tuckie,
    Here's a solution:
    Attached is a zip containing a little script called "resumepause".
    This script was built using Autohotkey (http://www.autohotkey.com).
    I've included the script source (.ahk) and a standalone executable (no autohotkey install required).
    This script does the following:
    -Sets Centrafuse to be the active window (just in case).
    -Sends Ctrl-Alt-P (pause/play shortcut) to CF.
    -Exits
    Unzip this in a folder you can remember on your CarPC.
    To run it when CF resumes/starts/whatever follow these instructions.
    -In Centrafuse, go to Settings and select General.
    -Go to Page 2 and click the "Click to Setup" button underneath "Startup/Shutdown Commands"
    -Choose your appropriate selection (in this example, "Resume"), by clicking it and then tap the right arrow (>) sign at the bottom.
    -A blank page will display. Click the + sign on the right to add a command to run on Resume.
    -Navigate to where you unzipped the resumepause.exe (or .ahk if you prefer to install Autohotkey and use it).
    -Click the resumepause.exe file and click OK below.
    -A box prompting you for parameters will pop up. Just leave it blank and hit the Enter key.
    -Tap the Close key and then Close once more and finally Save.
    Congratulations, you should have your system pause on resume just like you want it.
    If you want the music to pause on a fresh boot/start as well, follow the same instructions and replace Resume with whatever startup function you want to control.
    Hope this helps.
    It should also be noted that you may be able to go into CF's settings and turn Autoplay Media OFF and not have your music play on startup.
    I'm not sure if this works for Resume, however.
    Either way, you've got options to accomplish what you want.
    Best of luck...
    -P
    Attached Files Attached Files
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by hatton920
    This was a bug and has been fixed...
    david
    FLAC mbkowns's Avatar
    Mar 2004
    SOCAL
    what about having it so it pauses for like 4 seconds and then unpauses?
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
    Sep 2005
    North Carolina USA
    Quote Originally Posted by mbkowns
    Done...attached.
    All this is quite easy with Autohotkey (source included).
    -Activates CF window
    -Sends Control-Alt-P to pause
    -Sleeps for 4 secounds
    -Activates CF window (just in case)
    -Sends Control-Alt-P to play
    -Exits
    Good luck...
    -Paul
    Nov 2004
    thanks, I got the exe working on resume... although for some reason centrafuse couldn't see the exe if I just placed it in the C drive.
    Do you know if there is a way for it to detect whether or not it is already paused? Perhaps veetid could hook me up with a separate hotkey for pause?
  1. Auto Hibernate
    By mjg7876 in forum Other Cool Stuff
    Last Post: 02-20-2015, 12:05 AM
  2. Resume after hibernate scrutinized
    By ldave in forum PowerVoice
    Last Post: 02-09-2006, 11:04 PM
  3. Auto Set Volume After Hibernate
    By djXternal in forum FrodoPlayer
    Last Post: 07-30-2005, 02:08 PM
  4. Audio crash after hibernate (USB alerts)
    By Peoples in forum RR Bug Tracker
    Last Post: 03-10-2005, 01:29 PM
  5. Auto hibernate on no power.
    By detz in forum General MP3Car Discussion
    Last Post: 02-22-2004, 04:45 PM
