Results 1 to 4 of 4
Thread: Carmera with slow FPS in Centrafuse?
    Apr 2005
    Heyo once again,
    i've just bought an inredible expensive webcam (20 bucks^^) to use with centrafuse. the cam features 30fps at 800x600 which works like a charm in amcap or any other captureing software.
    but when i set up the cam in centrafuse it gives me aprox 5fps only with huge delay. is there any way to prevent this?
    thanks
    My Car-PC: Athlon XP Barton 2800+, 512 MB Ram, 60GB HDD, Radeon 9800 Pro, 7" Touchscreen MM400 :)
    VENDOR - Centrafuse veetid's Avatar
    I have only tested with logitech and they seem to work fine... Is it using WDM drivers? Try clicking on the title bar that says CAM1 to pull up the settings and see if there is anything you can change...
    david
    Mar 2006
    my camera is very slow fps as well. Its plugged in through a PCI card, and using its native app, it runs at normal fps, using Cf, it runs very choppy...
    Apr 2005
    Quote Originally Posted by veetid
    david
    its using quite standard wdm drivers, ive tried with my other three cams too - same result. i've ended up embedding my camera-capture software 'amcap.exe' via the external app function...
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Centrafuse SDK Information
    By veetid in forum CF SDK
    Last Post: 11-03-2005, 04:18 AM
  3. Slow visual fullscreen
    By Goddy in forum FP Bug Reports
    Last Post: 07-24-2005, 01:12 PM
  4. Centrafuse has gone really slow...
    By FociMan in forum Centrafuse
    Last Post: 06-22-2005, 04:04 AM
  5. Centrafuse Launcher (Fixes Map Movement)
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-02-2005, 03:53 PM
