Use this codecs packagehttp://www.free-codecs.com/download_...hp?d=1245&s=95
The old setup http://flickr.com/photos/ilyassx
The new setup http://my.opera.com/ilyassx/albums/show.dml?id=110701
Jetway J7F2WE VIA C7 1.5 GHz
512 DDRII 533
3.5" SATA2 H.D.D 200GB
M1-ATX
ELM327MS OBDII
Creative Audigy 4
PROGRESS:[########-]90%
This package is what I am using now, well not exacty, 2.66s version. I will install the new version to try. I must configure it in some special way?
enable all codecs and all default processing, activate resampling option to 48000Khz that should be ok.
512 DDRII 533
M1-ATX
ELM327MS OBDII
Creative Audigy 4
That's so old and tired, use http://www.softpedia.com/get/Multime...ecS-Pack.shtmlOriginally Posted by ilyassx
codec packs are generally a very very very bad idea to install... You can playback everything if you simply install an mpeg2 codec (powerdvd, windvd, etc), ffdshow, and ac3filter... that's all you need, no junk...
david
Thank you very much.
