Originally Posted by swiftly93
It works for me. Just make sure you check for the necessary drivers/files and intstall them before you try to run Centrafuse.
ie: dotnetfx......etc etc
but it does work quite well on Tiny
Good Luck
Has anyone installed Centrafuse on TinyXP rev04 ?
I am having some problems getting the software to run correctly. it starts and asks for the registration info, then it asks me to enter the setup, Once I select close on that screen it just crashes out...
These are the errors showing up in the Centrafuse log.
1/05/2006 11:13:20 AM
Object reference not set to an instance of an object.
at centrafuse.main.runLaunchCommands(String section)
1/05/2006 11:13:28 AM
No connection could be made because the target machine actively refused it
at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
at PhoneControl.PhoCoInterface.Init(Int32 pi_iPort, String pi_sHost)
at phone.phone.CF_pluginInit()
Any help is much appreciated.
Cheers
Good Luck
BTW:
disable phone control. that is one of your biggest probs right there.
you gottafor the one
Thanks for the feedback, I havedisabled the phonecontrol plugin and it doesn't seem to help much.
350Ztoy can you point me to the version of .net you are using ? I have a feeling this has something to do with it....
Cheers
I have been using 1.1
here is the link for the same file I am using.
Good Luck!
http://www.microsoft.com/downloads/d...displaylang=en
it's a good choice to install centrafuse on tinyxp ? faster bootup ? or something else ?
Faster bootAnd for some HD space.... If you are booting from a CF card, then TinyXP will be great for that.
anybody find a suggestion to this....i get the same error. Also im usingthe Via motherboard and when i try to install the video drivers off the cd i get more errors.
check this thread i made,HEREOriginally Posted by darksideofjae
Did you install .NET 1.1?
Im using a M10K with the drivers off the CD, try to Download the newest ones from via..
Originally Posted by camsgs3
I got framework 1.1 and was finally able to get the video drivers installed. But im still getting that same error.
