Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 67
Thread: VFD feedback
  1. #11
    Apr 2006
    I have an EPIA board which has a parallel header on the MB. I connected a ribbon cable up to that, and a shielded parallel printer cable to the ribbon, which was quite long. I'm going to take out the printer cable and just use the ribbon cable with my new 16x2 display, so we'll see how that goes. I got no corruption using other display software like LCD Smartie - so I don't think it was hardware related. I'll keep that in mind though.
    Be interested in how you go Mark.
  2. #12
    May 2006
    Seattleish, WA
    Well, I just wired up a cable, plugged it all in and it looks like I probably crossed a line. All I get is a line of solid blocks across the bottom. Centrafuse _is_ trying to write to the display, you can see it clear and then the blocks come back.
    I'm out of time to mess with it this morning, and I'm gone for the weekend, but I'll be back Sunday night.
    More when I know more!
    :: Mark
  3. #13
    Apr 2006
    Soldering VFD display
    Yeah soldering the parallel connector is an exercise in patience. I got an electronic engineer mate to do it because I don't have the skills - in exchange for me creating a website for him.
  4. #14
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    Quote Originally Posted by BigTones
    ...I got an electronic engineer mate to do it .... in exchange for me creating a website for him.
    AHHAHAHHH!!!!
    Sorry but I don't think it was a good deal...
  5. #15
    VENDOR - Centrafuse veetid's Avatar
    bump...
    Any word on if the VFD output is working? I don't have a working VFD and I can order one for testing, but it worked before mine broke...
    midiwall, anyone else... did it work for you? if not what problems are you having...
    david
  6. #16
    May 2006
    Seattleish, WA
    Hi David;
    Sorry, I got tied up with a new job and a couple of other things. I'll get back into it tonight!
    :: Mark
  7. #17
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    david i can send you a vfd display if you want to use it for testing...
    here is the catch...you send me a cable to connect it to the pc so i dont have to make my own. :-)
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  8. #18
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    Couple of questions about VFDs.
    Will it only support Parallel VFDs, or can you use serial/parallel ones?
    Also, what can you output.
    I'm wanting to play with a VFD as a HUD when I build my next install (might be some time) and would love to be able to output say GPS directions on line 1 and 2 of a 4 line, and GPS speed on line 3 and 4. Or maybe OBDII speed and revs on 3 and 4, with the GPS stuff on top, with the top section being switchable from GPS to mp3/cd details or maybe auto displaying audio between direction updates. Can it do that, or is it planned to do that?
    4x4 in a turbo stylee.
  9. #19
    It currently only supports parallel.
    You can see what all you can output in settings.
    david
  10. #20
    Constant Bitrate AngryMan's Avatar
    Aug 2005
    Lewiston, Maine
    Quote Originally Posted by veetid
    david
    Im still having trouble with mine.
    Ive posted the symptoms before.
    HD44780 LCD problem in cf 1.5
    originally posted for 1.5, I waited for 1.6 to come out and had the same problems. then another guy "BigTones" said he got his working, so I rewired another one of mine to use a bigger potentiometer thinking the contrast was an issue.
    here is what I have learned about parrallel LCD's running the hitachi HD44780 proccessor.
    software contrast adjustment DOES NOT WORK. I can use the LCDs just fine with "lcdcenter" so I know they work perfectly. but when I use a software program to adjust the contrast, they hang. - this is what I think CF is trying to do which is causing it to show nothing but bars.
    Here is what my lcd works like when using LCDcenter2.0
    as you can plainly see, this works perfectly well. even so far as scrolling custom text, cpu load, bandwidth in and out, things like that.
    but as soon as I fire up CF and try to use it:
    all I get are the "bootup test bars" and no happy scrolling text.
    it could be something as simple as CF not properly sending the syncup signal to the LCD. because if I fire up cf and tell it to use the LCD then fire up lcdcenter to get it to scroll some text, the screen will fight between being blocked and showing text.. - ie "flickering"
    good luck with this David! I want to install the lcd in my dash admidst my speedo cluster and stuff, so I can read off the song playing and stuff without taking my eyes so far off the road..
    .______
    / '__|__\____ VW CarPC project
    \(o)_____(o)/ Full Spead Ahead!
    Props to my Sponsor, Summit Adventure Systems Mobile Climbing Walls
    www.summitadventuresystems.com
  1. VFD Display
    By leesilk in forum LCD/Display
    Last Post: 04-20-2009, 11:32 PM
  2. Line Feedback
    By 2k5f150 in forum Car Audio
    Last Post: 06-09-2005, 09:34 AM
  3. SMK Force Feedback Touch Panel
    By e_z_street in forum General Hardware Discussion
    Last Post: 03-11-2004, 07:01 PM
  4. Serial 4x20 VFD for Sale $75 Shipped
    By johnram in forum Classified Archive
    Last Post: 06-21-2002, 05:26 PM
  5. My VFD came today. Now what?
    By King_Xerxes in forum LCD/Display
    Last Post: 04-22-2002, 11:02 AM
