I am mainly trying to figure out why some devices are working with Centrafuse and some our not. If they are both HD44780
parallel devices, they should both work...
I know you can get them to work with other softwares, we need to try and figure out why one works with Centrafuse VFD output and the other doesn't...
I assume I need to just order a few different VFD's to play around with...
There are also timing settings for the VFD that might could be tweaked to make it work... They are under settings or in the vfd xml file in the system folder...
david
