Does hibernation work properly if CF isn't running?
veetid,
I believe I have found a bug, but I'm not sure if anyone else has seen this.
I have a fresh Windows XP SP2 installation, with Centrafuse 1.6. I have not installed various dependencies yet (Destinator maps, etc) on this particular install. In the Centrafuse settings, I have set Hibernation.
When the key is turned off, my OPUS 150 triggers the shutdown, and everything seems to hibernate. However, when turned back on, BIOS boots, then the initial Windows black screen with white bars goes across about half way, and then it says something along the lines of "Windows can not properly boot with the current settings, do you wish to Delete the restore point and continue booting?" And saying yes to that boots everything up just fine. However, it seems every time this happens.
I have tried other Centrafuse shutdown settings, like for Shutdown, and Standby, neither of which seems to work at all. I remember with previous releases, we needed to set this in the OS directly, so is there a bug with how Centrafuse talks to the OS to set this?
Any ideas?
Regards,
Kevin
Kevin
Audi A4 Carputer, 80% setup.
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
Quick answer.
When your shutting down sometimes not all the times becuase it worked before the power is getting cut before the OS is done hibernating and that will cause that problem.
Also search around this is a common problem. Alot of times has to do with a hung app that won't let the computer hibernate.
2005 Ford Mustang GT <- - - UPDATED PICTURES
2003 KAWASAKI Z1000 - CUSTOM MODZ
MBK (AIM = IllMBKllI)
