Results 1 to 7 of 7
Thread: Ipod in CF?
    Mar 2006
    Ipod in CF?
    I tried to hookup my ipod to my carputer and it was a success. Detected and installed. Then in CF i tried to play songs off the ipod, but when I click on the "external drive" (the button below the cd drive button) it tries to get a list of the songs from the ipod.. Now the problem is that it says estimated time = Infinity! So I was wondering if I did something wrong, or if this was normal. Also if I don't change the ipod at all, will it have to do this everytime? BTW my ipod is 40 GB, but has roughly 25 GB on it now. Thanks!
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    i have the same problem with a simple USB storage dongle. I think the prblem comes from the "import songs" function.
    Mar 2006
    When I connect mine, it always tells me "no usb device found." I can't figure out why its not found. It comes up fine in itunes. Any suggestions?
    Variable Bitrate inniss777's Avatar
    Oct 2003
    SOCAL
    Quote Originally Posted by jhanson999
    I get the same problem.
    Opus case. MB 899 core duo 2.0ghz
    Dual vga out, 400 gb hard drive, Centrefuse front end
    zapco 1000.4 for zapco 6.5 componets
    zapco 1100.1 for 2 13" W6.
    Apr 2006
    I plug in my usb drive and it works. Unplug it and try to plug it in and it didnt work. (my usb drive is my phone tho) Something like that + hibernate didn't work.. ill test more later..
    Mar 2006
    Thos of you who do have it working.... do you have itunes installed, or no?
    May 2006
    Seattleish, WA
    I have a similar issue with my H10.
    I worked around it by creating a Music Path that points to the H10 media folder and then not using the USB button, and instead use the normal local browse button to hit the path directly.
    I think David's talked about this in another thread and mention that attempts to rebuild the library will be smarter in RC2.
    :: Mark
  1. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 07:48 PM
  2. FS: ipod 1.8" HD 20 gigs + cf card hack
    By churnopol in forum Classified Archive
    Last Post: 08-29-2004, 02:24 AM
