Results 1 to 10 of 17
Thread: Random music play bug?
    Jan 2004
    I got some problem in Random mode.
    If you press the Prev. song button more than once, then it choses a random song, and are not selleting the prev. song?
    Isent it posible for CF to rember the playlist like eg. Mediaengine?
    Also if you press next song, and then prev. song and the next again, then the song is different that the first song?
    Jan 2004
    BTW: is it posible for the Navigation in CF to use 2 gps unit, one as primary and on as secondary?
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by clemen
    what does that mean and why would you want to do that?
    Jan 2004
    Quote Originally Posted by tj!2k4
    I just got a few BT gps units for free, and then i wanted to make a backup system, so if the one gps units lost its contact then the other would take over, (its placed at another location)
    Oct 2004
    Cool, where do I sign up for one of these free bt gps?
    As far as the question is concerned, I don't think that's possible. Each gps would be connected via a different [virtual] serial port, and none of the navigation software that i know of can accept concurrent input from multiple serial ports.
    Are these strictly battery powered? If you have the option to power it via the car's electrical system, do that.. there's really no reason that the gps should lose contact then.
    May 2005
    Vienna, VA
    One would easily writes an app that monitors both ports and checks for validity in the NMEA strings and outputs the valid one to another port, where the GPS software is connected to.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
    Oct 2004
    ^ it would be interesting if such an app could accept the input from multiple GPS units at the same time and provide an average.. might make for better accuracy..?
    VENDOR - Centrafuse veetid's Avatar
    This would be best done by creating a seperate program that created a Virtual COM Port. Then in the applications settings you told it what COM ports all your GPS receivers were on and it feed the information to the virtual COM port, that would then be used in any GPS application...
    david
    May 2005
    Vienna, VA
    "Averaging" the signals is not necessary. You only need to check for the checksum in the NMEA string.
    clemen's idea is actually a pretty good one. Your best bet is to ask Curiosity, the guy who wrote xPort3, to make this an option in his app.
    Maximum Bitrate P3rv3rt B3ar's Avatar
    Jul 2005
    Funland
    Good idea, I think one of the most important advantage would be direction... since it wouldnt anymore have to be counted on movement.
    BTW: this thread is bit OT
  1. winamp play video in music mode?
    By tundra2000 in forum Road Runner
    Last Post: 05-18-2006, 12:10 PM
  2. How to play music and use FD
    By Baz in forum FreeDrive
    Last Post: 04-21-2005, 01:14 PM
  3. New Release CENTRAFUSE 1.1
    By veetid in forum Centrafuse
    Last Post: 01-18-2005, 10:17 AM
  4. Winamp doesn't play, but the play sign is there
    By mbowler in forum Software & Software Development
    Last Post: 08-03-2000, 07:46 PM
  5. MPXPlay / MPXF ... random play
    By DaBretty in forum Software & Software Development
    Last Post: 07-20-2000, 10:32 PM
