Results 1 to 8 of 8
Thread: 800x480 support?
    Constant Bitrate shiltz's Avatar
    Dec 2004
    Massachusetts
    800x480 support?
    I was just wondering if the latest version of Centrafuse has the 800x480 support built in yet or not? I didn't see anything when I searched that said one way or the other if it did.
    I always wanted to use Centrafuse back when I built my carputer but the lack of the 800x480 kept me from using it and was just thinking about it today and figured i'd check to see if that's changed since then.
    2005 Dodge Magnum RT, Samsung Galaxy Tab install
    Elsewhere
    Resolution is dependent on the skin you're using, not the program itself. All you need is an 800x480 skin.
    How about the Wiki?
    Oct 2004
    NY
    ...& even if you use the standard skin, it can be scaled by centrafuse to display at any given resolution, 800X480 is no problem..
    VENDOR - Centrafuse veetid's Avatar
    you can set the resolution to anything by opening the config.xml file...
    I have added the ability to add custom resolutions from the Settings GUI in 1.7...
    david
    Dec 2004
    Massachusetts
    Quote Originally Posted by turbocad6
    Cool, it couldn't do that when I had built my computer, it was just 848x480 and 800x600 back then, you could tell it 800x480 but it wouldn't scale, it would just crop off those extra 48 pixels from the 848x480 res and making a custom skin seemed to take a little more programing ability than what I have, lol.
    Guess i'm gona have to download it now to try it out
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    I assume you were using 1.3 or before. The scaling support has been there since 1.4 I believe.
    Dec 2004
    Massachusetts
    Yeah, was I belive 1.0 and 1.1 back when I was building my computer.
    Maximum Bitrate P3rv3rt B3ar's Avatar
    Jul 2005
    Funland
    Quote Originally Posted by RPM_VR4
    First one I used was 1.2 and im pretty sure that had scaling suport already... might be that im mistaken though...
  1. Tech Support Calls
    By Rafster in forum Off Topic
    Last Post: 06-12-2006, 12:49 PM
  2. does Nano-ITX support native 800x480 resolution onboard ?
    By calico in forum General Hardware Discussion
    Last Post: 03-04-2006, 04:56 AM
  3. RR 08-30-05 ... Ipod Support & Fixes ...
    By guino in forum Road Runner
    Last Post: 09-09-2005, 06:50 AM
  4. 800x480 V8000 BIOS & Driver from VIA GmbH Support
    By ShawJohn in forum LCD/Display
    Last Post: 12-08-2004, 04:02 PM
  5. Xenarc 700TSV 800x480 Support
    By auto_robotics in forum LCD/Display
    Last Post: 08-27-2004, 01:33 PM
