S&T2K6 does not provides any programming model, but works fine with CF as an external application. Integration as been done using MapPoint 2k4 (2k6 working fine). If interested, then check the CF plugin forum.
Just wondering if there is a successful integration of S&T on CF? I love CF the most, but I wish I could use S&T within it!
Jim
2005 Acura TL
2005 Honda VTX1800N
PreludePC 2.0 in the making...
Smaller, faster, better...
looks like it's still an issue for 1.7 - hit launch, and it just pops up a white screen and sits.
might have to buy map point now. hmph. anyone want to buy my copy of S&T2k6?
Originally Posted by EMT2B
The problem is the "&" symbol centrafuse doesnt like the symbol but if you install Streets & Trips with the word "and" instead it works fine. (Ex. Streets and Trips)
You don't have to use full window names, you can use partial and it should find it also...
david
Ahh crap you beat me to it.Originally Posted by veetid
Example you can do something like this for find window: "Microsoft S" or
"Streets "
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
I use Streets & Trips 2K6 and I get great integration with RoadRunner.
ok, got it runnign in CF.
now, when i CLOSE S&T, the white window stays open, and when i attempt to close it, the player pauses, and further attempts to close the white window will resume and pause.
has anyone else noticed this, or come across a fix? Once i start S&T, i can no longer get back to the main menu.
