Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 63
Thread: New Release, Centrafuse RC1 (1.7)
  1. #21
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    I had an issue with MSI files not being recognised.
    downloading Windows Installer 3 from MS fixed it
  2. #22
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    just downloaded it through firefox.. it came down named centrafuse not centrafuse.msi a quick rename and it installed fine
    CdR
  3. #23
    Apr 2005
    Queens, New York
    I too had to rename it and put msi as the file type...weird!
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  4. #24
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by diskey
    correction:
    I meen, microsoft has that tool, must be downloaded from microsoft.com
    That's correct. Here's the link. http://support.microsoft.com/default...b;en-us;290301
    Superbowl:
    Install the app linked above, run it, and remove anything that has to do with centrafuse. Then install as normal. Should do the trick.
    Tidder
    Try RevFE
  5. #25
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Quote Originally Posted by Cheekz185
    Not wierd, David (or whoever posted the file) did the classic internet no-no of putting spaces in a file name.
    David, please rename the download on your site so it DOES NOT INCLUDE SPACES. This will prevent problems with firefox users.
  6. #26
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by Jahntassa
    This has been fixed...
    david
  7. #27
    May 2005
    Conyers, GA
    Quote Originally Posted by veetid
    david
    Sweet, thanks! Took a look and firefox downloads correctly now.
  8. #28
    May 2005
    Conyers, GA
    Looking through the setup I see a section including something about behavior when the ignition is turned off..
    I'm unfortunately running an Inverter based system with no soft power switch. David, is there ANY way that CF can read some sort of trigger on one of the serial ports to set the system into hibernate? I still haven't run into a good software solution that hibernates the system as well as hitting the 'sleep' button on a USB keyboard.
    Pleeeeeeease..
  9. #29
    Aug 2004
    On the edge!
    well I tried it at work and it seems fine, but on my Tiny'd CarPC it installs ok, and enters setup, but won't scan music library, and then when exit setup, no button labels show
    I know its a TinyXP issue, but thought I'd post anyway incase someone has a solution.
    Is there anyway to get a list of dependancies so we can find out whats missing?
    Other than that minor hickup its looking very sweet indeed
    John
  10. #30
    Jun 2005
    I have some uk maps which have loaded into this beta but it wont show any street names. Trying to add a route in just shows nothing in the box on the left. Any ideas?
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Centrafuse 1.7 / 1.8 / 1.9 / 2.0
    By mbkowns in forum Centrafuse
    Last Post: 06-19-2006, 02:55 PM
  3. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 04:13 AM
  4. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 10:17 AM
