Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 63
Thread: New Release, Centrafuse RC1 (1.7)
  1. #51
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Arrow Loss of GPS
    just noticed that 1.7 stops D3 based GPS from working.
    Which makes GPS useless unless you have D6 maps of your region !
  2. #52
    Variable Bitrate lazy_g's Avatar
    May 2005
    Netherlands (Bergen (NH))
    Quote Originally Posted by ShawJohn
    Just reinstall D3 overit, and use mapmonkey, or freedrive embedded.
    works fine for me! only problem, the nav plugin will not work anymore....
    www.superchargedmiata.net - all about roadster lifestyle
  3. #53
    BGH
    BGH is offline
    May 2006
    Melbourne, Australia
    Is that what would be causing this problem
    Australian Destinator maps supported?
    along with a similar problem others in this thead seem to be having?
  4. #54
    Low Bitrate DaKyy's Avatar
    Apr 2005
    Finland
    it does, just put your location in as, cityname, countryname.
    So it seems, only my city isn't there Had to select the nearest. Shame, Accuweather would've been more accurate. Is there any way for adding additional cities - for example the "home" city and the destination city.
  5. #55
    Aug 2004
    On the edge!
    go to weather.com and find your city on there to make sure it exists.
    This is where the info comes from so if it works on the web, it should work in CF.
  6. #56
    Aug 2004
    On the edge!
    Exclamation CF Must use 2006 maps
    Quote Originally Posted by BGH
    Sounds like these are Destinator PN maps and you need either Destinator 6 / 2006, or Destinator ND maps. I've got Destinator 2006 EU for my PDA which comes with Q1,2006 Maps and these work fine
    I'm getting a little confused myself now as to what all these different versions of Dest are, I think D6 is D2006
    Be warned though, that CF1.7 RC1 WILL stop programs like Freedrive, GaroNav & Map monkey from functioning as the Dest.dll files are different and will not co-exits on the same PC, and if you re-register the DLL file with regsrv32 it stops CF1.7's nav from working.
    @David,
    I notice that TMC options are included in the .ini files, is this working... Also what about speed cams, will it warn about those...
    Is there some secret way of accessing the D6 menu now the Nav Menu button has gone, there appears to be no way to change some settings without getting hands dirty in .inf files.
    Just got finished up with my new install so will hopefully get it back in the car tonight for some proper on the road test
    Found some minor problems with external apps section not creating the XML files properly and it stops buttons displaying, managed to fix problem manually though by editting them in notepad and checking format with IE
    John
  7. #57
    Variable Bitrate LanoX's Avatar
    Aug 2004
    Sydney
    Hey all i was wondering if is this a bug or just the way is suppose to be when you are watching video clips and you go to full screen and in full screen if you press >> it fast forwards the song is there any possible way when you press >> to skip to next song like it does when you not in full screen.
    [|||||-----] 95% complete
  8. #58
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by LanoX
    I have thought about this... I do like the idea of skipping within the movie as well...
    I might just make it skip and next track, but not sure...
    I will think about it...
    david
  9. #59
    Constant Bitrate 2 STanGeR's Avatar
    Aug 2005
    Terre Haute, IN
    Yeah, now I am used to be able to next track and fast forward with the same button. I would have thought you would have kept it the same in full screen.
  10. #60
    FLAC mbkowns's Avatar
    Mar 2004
    SOCAL
    Quote Originally Posted by veetid
    david
    DAVID, WHY NOT JUST MAKE A SLIDER! THAT WOULD SOLVE THIS PROBLEM MUCH BETTER LOL
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 07:12 PM
  2. Centrafuse 1.7 / 1.8 / 1.9 / 2.0
    By mbkowns in forum Centrafuse
    Last Post: 06-19-2006, 01:55 PM
  3. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 03:13 AM
  4. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 09:17 AM
