Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Possible fix for navigation issue reported by some people
  1. #11
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by clemen
    David -> Still no fix on the port problem?
    I'm looking into it... I have been able to reproduce it, but all I do is keep changing the COM port until I get one that works, and it stays working...
    It works perfect with my serial GPS hooked to a hardware serial port, but for example with the Earthmate USB/Serial driver I have had it do as everyone has explained...
    I just kept going up with the virtual COM port until it worked, and it stayed working...
    Anyway... I'm looking into it... I should know more in a couple of days..
    david
  2. #12
    Newbie TheRock's Avatar
    Jul 2006
    Hy guys i had the same problem with the com-port.
    Then i use the tool ShowGPS and at the moment it works.
    With this tool you can test your com-port,detect optimal settings and you can also solve the com-port problem sometimes.
    link: ShowGPS Site
  3. #13
  4. #14
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    I cannot get GPS to lock on, and it doesn't seem to matter what settings I use.
    It locked on whilst outside my house last night, but then won't even try today whilst the car is moving.
  5. #15
    Jun 2005
    Slovenia
    My GPS was totally reluctant for some time to start, I was playing around with the SIRF settings. After I put everything back, no matter what I did, the GPS stil wouldn't start.
    Then I went to the Centrafuse directory and manually startet the destinator.exe. Locked to the satellites immediatelly. After that, if I play around with settings and the nav in CF doesn't seem to find the satellites, I just go out, run destinator.exe, close it, go to CF again, and it works.
    Seems that not all the settings made in CF are stored properly or something like that...
  6. #16
    Aug 2004
    On the edge!
    might be another XML file corruption issue, will check later on
  7. #17
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    Quote Originally Posted by andro
    same feeling here
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  8. #18
    Aug 2006
    Murcia, Spain
    I use a Bluetooth gps receiver and i solved this bug instaling GPSGATE. Usign a virtual port the gps works propertly.
  9. #19
  1. Replies: 30
    Last Post: 07-28-2010, 10:14 PM
  2. Possible fix to a power issue???
    By jbyers in forum General Hardware Discussion
    Last Post: 08-25-2005, 06:58 AM
  3. Replies: 10
    Last Post: 05-10-2004, 04:08 PM
