Results 1 to 10 of 19
Thread: Possible fix for navigation issue reported by some people
    VENDOR - Centrafuse veetid's Avatar
    Some have reported the Navigation is not loading, but going into a little black square in the top left corner.
    You might try the following:
    Open a command shell in the Centrafuse directory, then enter this:
    regsvr32 DestSDK.dll
    Hit OK on the dialog and restart Centrafuse. This was suppose to happen, and it did for all my test machines and a lot of users on the forums, automatically. I am looking into what could cause it to sometimes not work.
    david
    Aug 2005
    In the settings, how come we are not able to modify the Navigation display name? I was trying to change "NAV" to "GPS" and couldn't find a setting for it.
    Quote Originally Posted by L-U-R-C-H
    I don't have that editable, but you can easily change it in the language file... It's an XML file with the name of the language you have set in Languages folder under Centrafuse...
    david
    Aug 2005
    Yeah I was just curious because in version 1.6 it was editable. Thanks for the info David!
    Newbie Garmac's Avatar
    Jul 2005
    Washington, DC
    Thanks David, that was it... worked like a charm after registering the dll
    Micron GX2 with P3M 1Gz and removed screen, Pyle 7" VGA Touchscreen 800*480, 512mb Ram, Dvd rom USB2 in front, ati M6 Video with 16Mb, 250 gb 3.5" firewire External, 60 Gb 2.5 int, Car2PC, Xtreme Radio, Bluetooth, Cam, CENTRAFUSE 1.6!
    Oct 2004
    NY
    Hi, please excuse my ignorance, but could someone please tell me how to open a command shell in the centrafuse directory?
    Quote Originally Posted by turbocad6
    go to start/run and enter cmd.exe
    This will bring up a dos window. Then navigate to the directory where you installed Centrafuse, for example type:
    cd "c:\Program Files\Flux Media\Centrafuse"
    Then issue the command..
    david
    Oct 2004
    NY
    thanks..
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    so am I right in thinking that D3 & D6 cannot reside on the same PC.
    Cause after installing CF, Freedrive's maps won't load, then on reinstalling FD, CF's Nav doesn't work, as mentioned above.
    I pressumed the Dest.dll file for D3 had been updated in D6 but kept the same name, hence the incompatibility, now it seems it is DestSDK.dll in D6
    Jan 2004
    David -> Still no fix on the port problem?
  1. Replies: 30
    Last Post: 07-28-2010, 10:14 PM
  2. Possible fix to a power issue???
    By jbyers in forum General Hardware Discussion
    Last Post: 08-25-2005, 06:58 AM
  3. Replies: 10
    Last Post: 05-10-2004, 04:08 PM
