Results 1 to 10 of 13
Thread: CF 1.7 Day Skin?
    Apr 2006
    Davie, FL
    CF 1.7 Day Skin?
    Hey all,
    Has everyone but me seen the new Day skin? I can't seem to get it to appear! I have the times set in the Genreal settings: Day switch time = 8 AM and night switch time = 8 PM. I have tried this with the Auto Switch Skins button set bot on and off, but I have yet to see the day skin! Am I missing something?
    VENDOR - Centrafuse veetid's Avatar
    There is a bug in the auto switch... The machine has to be on at the exact time it's suppose to switch...
    You can manually switch to the day skin by holding down the dim button for 4 seconds...
    david
    Variable Bitrate bishooman's Avatar
    Jan 2006
    Kuwait
    Quote Originally Posted by veetid
    david
    also this button should be fixed !!
    the event should fire on button down not button up, the skin is being changed when you remove your finger off the button which is not good cuz in this case i cant know if i reched 4 sec or not !!
    and by the way 4 sec is tooooooooo much!!!
    We Exist because there is no patch for human Stupidity !!
    We need you ALL Here !!
    Quote Originally Posted by bishooman
    We are looking into a better solution... The reason is because if you hold it down for 2 seconds, the screen will black out completly, if you hold it down for 4 seconds the skin changes...
    It use to be 2 seconds and on down after 2 seconds it auto blacked out... We just last minute needed a place to put the manual skin change and that is where it ended up...
    david
    Apr 2006
    Davie, FL
    Thanks David! I'll try that.
    Raw Wave justintime's Avatar
    Apr 2005
    Audio feedback would work well for that. Make one beep after 2 secs reached, make 2 beeps after 4 secs reached.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Jan 2006
    Kuwait
    david
    what is black screen for ??
    Just a feature that was asked for at one point, maybe I don't need it... It was just if you didn't have access to a power button for your screen because it was custom installed in your dash, you have a way to black the screen out during the night if you don't want the bright screen...
    david
    Jan 2006
    Kuwait
    david
    ok you can move the black screen to visuals and keep the dim button for skin change and dimming only
    Apr 2005
    Instead of black screen, how about use that for LOCK SCREEN function?
    2002 Honda CR-V
  1. MMI eXtnd
    By proTONEd in forum FP Skins
    Last Post: 04-17-2008, 06:26 AM
  2. Open Source Skin Editor for RR
    By lbooker in forum Road Runner
    Last Post: 04-16-2007, 02:51 AM
  3. CF 1.7 - Europe Questions
    By Linde in forum Centrafuse
    Last Post: 03-08-2006, 08:47 AM
  4. CF 1.4 skin for CF 1.2
    By superbowl in forum CF Skins
    Last Post: 08-08-2005, 05:19 AM
  5. 800 x 480 CF Skin?
    By Anees in forum Centrafuse
    Last Post: 03-29-2005, 06:36 PM
