I will answer some of your questions.
This is a configuration thing. Open PhoneCtlConfig.exe from the PhoneControl.NET path and go to the Communication [SonyEriccson New] section where the phonebooks are defined. Search for the RC phonebook then add showTime to the attributes list and set it to True.Originally Posted by bishooman
This applies to all non-static phonebooks.
I have been told that this happens on the remote interface but I couldn't reproduce and find the nature of it. I'm still on it.3-when i open inbox some time i get the same name for all messages , other time i get numbers even if i have these numbers saved in phonebook or sim and some times it showing correctly.
The headset symbol is shown only in case the PC is the headset (or the headset would connect to the PC - which doesn't apply here). There's no way the PC can figure that you've connected two other devices.4- headset is not shwing at all even when i connect my head set to the phone.
There's no relation between the bars in PhoCo / CF and the phone because it's different on each phone. The golden rule says: Many bars = good signal, Not as many = worse signal.5- signal is not showing correctly i have 2 or 3 lines on CF but the signal is full on Phone.
In fact it's every 20 seconds. On SE phones you could add the UseCMER option in the Communication section as described under (2) and set this to True then add attribute mode and set it to "3,0,0,1". This will cause the phone to report such things as signal quality as they change.6- refresh for signal , battry icons is veryslow.
For other phones than the SE this feature may not work!!
Yap, if you do this, you'll have to wait 20 seconds until the status gets refreshed. To get an immediate status refresh use the tweak above (6).8- when i am calling someone then i press the end button on the head set the calling dialog will not disapear and i have to press end call button on it to close and start music again.
peace
LinkBack URL
About LinkBacks
