Results 1 to 10 of 18
Thread: Daivd Can you add this to the Top Bar of CF ??
    Variable Bitrate bishooman's Avatar
    Jan 2006
    Kuwait
    i am working on a NCK 5 plugin and i need to show the GPS status indicator on the top bar of CF.
    can you make a place for one more icon that i can control from my plugin ??
    i need to add these is it possibale ??
    peace
    We Exist because there is no patch for human Stupidity !!
    We need you ALL Here !!
    VENDOR - Centrafuse veetid's Avatar
    currently plugins can't add things to the top bar, but I will look into the possibility...
    there isn't much room left, unless you don't use phone...
    I will look into it, for now you can show it somewhere in your plugin.. I don't show GPS signal everywhere, I don't see the need...
    note: Glad your working on an NCK plugin! If you need any help with the SDK let me know...
    david
    Jan 2006
    Kuwait
    Quote Originally Posted by veetid
    david
    actully i dont have the SDK i cantaccted them a lot for that but no body answers me.
    i am working on the application it self, it is already toutch screen friendly you can control its settings from its .ini files, i am working on Win API calls and send keys.
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    david
    I was deceived not to see it in 1.7.
    In my opinion, i think it is needed.
    Not necessery a bif icon...a little could be OK.
    FLAC alti's Avatar
    NY
    Quote Originally Posted by bishooman
    I started working on an IG plugin this week, using the same methods. Maybe we can bounce ideas off of each other. My code is a mess right now, as i was just trudging through embedding IG within the plugin, but I could clean it up a bit and share what I have. (c#)
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    Jan 2006
    Kuwait
    Quote Originally Posted by alti
    no problem at all, let me just code some functions and we will see
    or if you want we can both work in the same project (NCK) i choosed this cuz it has world maps support so it will work for any one
    Edit:
    i just found soemthing interesting go to http://www.autoitscript.com/autoit3/downloads.php and download you will get AutoitX3.dll and you can use this instead of bothering on WIN32 API pain
    FLAC alti's Avatar
    NY
    I will have to take a look at NCK, but i dont own it, but even if i contiinue on Ig I think our plugins will be very close to the same, mostly just differnt key strokes sent to the apps handle. Most of what we will want to try to control through CF is the same and the embedding process should be the same was well (minus the ig nag screen) I have IG embedding into a panel in CF, I am just working on getting to resize correctly on skin size changes.
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
    Jan 2006
    Kuwait
    man i am stuck here with embedding thing can you please send me a pice of code showing how you did that ??how did you embbded it into a panel ??
    thanks
    FLAC alti's Avatar
    NY
    pass the handle to the panel using the win API (included in the CF SDK ) Win32.SetParent(ChildHandle, ParentHandle)
    get the handle of the panel you create (yourPanel.Handle) and the handle of the GPS program window and add them as arguments to the line above.
    I am not home at the moment, but i will send you the code i am playing with later tonight. (which is embedding fine, but not resizeing yet)
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
    Jan 2006
    Kuwait
    actuly this is my problem gettign GPS program handel window how can i do that ??
  1. Replies: 24
    Last Post: 03-14-2006, 12:42 PM
  2. CF 1.4 and MM 1.3.xxx
    By SOS in forum Centrafuse
    Last Post: 08-08-2005, 09:20 AM
  3. Auto full screen and no explorer top bar
    By ThEScReW in forum Map Monkey
    Last Post: 11-30-2004, 05:01 PM
  4. Frontend 1.1.2 - Info Bar Up Top
    By Headsex in forum Map Monkey
    Last Post: 11-29-2004, 04:50 PM
  5. MediaCar Skin Sneak Preview
    By mindtool in forum MediaCar
    Last Post: 11-21-2003, 05:14 PM
