Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Selecting from multiple audio devices?
  1. #11
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by HTLuke
    That's great to hear David. Is that coming pre final release, or is it on the post-release future-features list?
    If the latter, could you consider adding just the ability (even via conf xml change, don't need a UI on it) to pick the one audio device that CF uses? That alone would at least let me send Windows and external apps sounds to separate outputs than the music/video sound which would be huge. Right now my GPS solution (embedded Teletype) loses much of its value because the spoken directions and alerts are almost always overwhelmed by the music audio.
    Adding individual volume levels on each discrete CF output channel would also work to some extent since I could lower the relative volume of the music, but since I already have three audio devices attached I'd rather just send the GPS audio out to an entirely different device which I keep at a constant volume regardless of the state of CF audio (I'd like my external GPS nav voice prompts to play even if CF is muted, for example).
    It is setup to be a post release feature right now, but if I get the time I can pretty easily change where I output the AUDIO for music, but VIDEO/DVD/TV/GPS voice prompts are all a little more difficult...
    david
  2. #12
    Registered User
    Feb 2006
    Berlin, Germany
    hi david,
    yes, it would be a nice feature to have more than one audio-output. Im on the problem with the rear-passengers rigth now. I want to send the video (not DVD) to the rear screen together with the video sound and want to use navi and music at the front sreen/speaker. Thats what you need in a car with kiddy seats.
    regards
    Matthias
  3. #13
    Apr 2005
    Dublin, Ireland
    I agree, that last feature would be the killer one that would be CF ahead of others, a lot of work im sure but i'd but it just to shut the people in the bacl up.
    P4 Celeron 2.2 - 512MB - OPUS 250 - Audigy SE - BU353 - HQCT - No Speakers though :-(
  4. #14
    Alright in the works, and shouldn't be that big a problem... I have a sample outputing the music to different speakers, channels, and sound cards...
    Just the main focus is getting this release out and then the bugs found within that release, then features can start to be added again....
    david
  5. #15
    Registered User
    Feb 2006
    Berlin, Germany
    Thanks David
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 06:25 PM
  2. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  3. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
  4. Seperate VGA and S-Video with Audio
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 07-01-2004, 02:44 AM
  5. Multiple audio in - potential problems
    By 4.9 EF Futura in forum Car Audio
    Last Post: 06-18-2004, 02:32 PM
