Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Error.log when running 1.7 on TinyXP rev.4
  1. #11
    Constant Bitrate urosbe's Avatar
    Mar 2005
    I tried with RC3 but still no luck It doesn't work on TinyXP rev2, rev4, rev5, beast edition, neither 1.7, RC2, RC3... probably I will give up soon
    Today I will try TinyXP Vista Edition... if it won't work, I give up
  2. #12
    Mar 2005
    Ok, RC3 works on TinyXP Vista Edition, but is seems slower than normal Windows XP... installation is big, a lot of programs installed, I would not call it "tiny"
    I am installing regular Windows XP Pro Edition right now (without any service pack), I also decided to go on FAT32. I will disable some process I don't need manually and hopefully I get performance I want
  3. #13
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    man you've been busy haven't you?
  4. #14
    Mar 2005
    Ok, I've installed regular WinXP without any SP and when installation was finished I've tried to install latest Via Epia drivers... unsuccessful. Ok, I decided to go on WinXP SP2 that I am using in my car for months and works like a dream, but before that I wanted to check if there exist some XP optimization tweaks (just for fun, even if I damage XP
    And I've found 2FastXP topic here on mp3car... in short... here I am attaching utility, that tweaks regular XP SP2 to that level that after reboot - Windows are using only 45 MB of RAM Lot of services are disabled... a lot of tweaks enabled... and Centrafuse RC3 is working - check it out!
    But I am not responsible if something will stop working... I am in the middle of fresh installation of regular Windows XP SP2... after it finished... I install latest drivers for Via and run this script I will report again I am happy now... after few XP installations finally something that is working
    Attached Files Attached Files
    System: VIA EPIA EN15000,512 MB DDRII,M2-ATX,300GB HDD,XENARC 1020TSV,VoomPC case
    USB: Powermate,WinTV+FM,WLAN 54G,Bluetooth,Haicom GPS mouse SIRFIII
    Software: Windows TinyXP Rev06+MinLogon+EWF+HORM+Centrafuse 1.2
    Honda delSol project
    CarDomain
  5. #15
    May 2006
    Nice find! Will try this tonight.
  6. #16
    Low Bitrate Gamer64's Avatar
    Feb 2006
    Holland
    Urosbe: What is your boot time? I am also fiddling around with minlogon but that won`t load Centrafuse (RC3) right (settings don`t get saved, missing buttons, menu etc.). It works when using Winlogon but it`s damn slow.
    This is the error from the logfile after running Centrafuse with Minlogon:
    Object reference not set to an instance of an object.
    at centrafuse.main.CF_localskinsetup()
    I read somewhere else that it`s some XML error when using an Nlite`d system (or TinyXP probably).
    Do you have the same problem with Centrafuse after your method of installing XP and adding the tweaks file? I would like to know if Centrafuse runs normally with your method & Minlogon.
    Thx in advance
  7. #17
    Mar 2005
    Hi!
    I never measured boot time... I am using hibernation, but I saw standby mode on my friend's carpc and I decided to try this instead of hibernation. All tweaks I tried with Windows were unsuccessfull for Centrafuse (the same error.log and missing buttons - settings not saving). The one and only thing that worked was this registry patch that I attached on page 1. Believe me, I have tried minlogon, all tinyxp installation etc... different versions of Centrafuse, all unsuccessfull. But the patch works great for me.
    Uros
    CarDomain
  8. #18
    Feb 2006
    Holland
    I also installed a fresh stock install now and applied the 2FastXP patch, disabled PreFetch, no Pagefile anymore. It runs quite nice, but until Centrafuse is loaded it takes some time.
    But works a lot better then minlogon.
  9. #19
    Apr 2006
    So I am not alone in this. I will just go ahead and full Windows.
  10. #20
    VENDOR - Centrafuse veetid's Avatar
    This user claims to have found the solution to the minlogon problem...
    Check this post...
    http://forums.fluxmedia.net/showpost...37&postcount=9
    david
  1. Running streetdeck on TinyXP rev4.0
    By segerdahl in forum StreetDeck
    Last Post: 06-03-2007, 10:17 AM
  2. power problems while car is running..
    By TimW in forum General Hardware Discussion
    Last Post: 03-18-2006, 09:11 PM
  3. Problem with ME 1.7 running video
    By mereg in forum ME Archive
    Last Post: 10-18-2003, 05:39 AM
