Results 1 to 10 of 20
Thread: Error.log when running 1.7 on TinyXP rev.4
    Constant Bitrate urosbe's Avatar
    Mar 2005
    I tried install 1.6 on TinyXP rev.4 few months ago and it was unsuccessfull install... when someone wrote here that he has the same problem I knew probably something is missing in TinyXP. But now I tried 1.7 (just to try) and install was successfull. When I run Centrafuse the wizard for setup appears and even if I leave everything default, there are no icons displayed (just blank buttons). When I restart Centrafuse setup wizard appears again.
    Framework is installed correctly, so I am not sure what else Centrafuse needs to run properly.
    I am attaching error.log
    Uros
    Attached Files Attached Files
    Slovenia (EU)
    Hmm, I was getting same symptoms (no icons and buttons did not work), when I was trying to install CF 1.7 on nLited XP with minlogon.
    I then put original winlogon.exe back and now it works.
    Raw Wave justintime's Avatar
    Apr 2005
    The problem you describe has occured for a few people including myself. I am using a regular XP install. So this is definitely not particular to TinyXP.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    I gave up on CF and Tiny.
    Lots of components missing that will cause error after error, best use regular XP
    Mar 2005
    I am still trying with TinyXP and Centrafuse. Today I installed TinyXP Best (666) edition I have to say, man it's fast Centrafuse was RC2, but still unsuccessful. The same problem as with 1.7 in TinyXP rev4... setup wizard appears, when you finish all steps, no buttons are displayed. After restarting Centrafuse, setup wizard appears again.
    There is also new edition of TinyXP rev.5 - it is a little larger, maybe I should try that one too And I am also downloading TinyXP Vista Edition (i will not give up
    David, you solved the problem with "blank buttons" in RC2.1, do you think there is any possiblity it should solve the problem on TinyXP also?
    I am attaching error.log from RC2 and TinyXP Beast (666 - hell fast) edition
    Uros
    Aug 2004
    On the edge!
    blank buttons is XP failing to parse XML files properly
    Or ofcourse, and error in the XML file
    May 2006
    Does anyone have a clue what is left out in an NLite'd XP or TinyXP install that causes this problem? Going back to full xp for the time being, but would really like to go with a 'lighter' XP on my CarPC
    Newbie mJrO's Avatar
    Jun 2005
    Portugal
    same problem. Tiny XP rev05
    This windows is just sweet but stayed up last night till 4 am trying to install cf 1.7rc2 but now i know it's not just me :S
    2005 S40 2.0D - Sport Body Kit
    Ipod 100%
    Carpc 95%
    Jun 2005
    Portugal
    Ok, here it is the list of everything that was stripped out of this version:
    http://rapidshare.de/files/32451532/...ssion.ini.html
    I already reinstalled firewire and pcmcia (needed them), what else should i reinstall?
    Ipod 100%
    Carpc 95%
    Aug 2004
    On the edge!
    XP Pro Full
    That'll fix it
  1. Running streetdeck on TinyXP rev4.0
    By segerdahl in forum StreetDeck
    Last Post: 06-03-2007, 11:17 AM
  2. power problems while car is running..
    By TimW in forum General Hardware Discussion
    Last Post: 03-18-2006, 10:11 PM
  3. Problem with ME 1.7 running video
    By mereg in forum ME Archive
    Last Post: 10-18-2003, 06:39 AM
