I agree on the random part it plays the same song to often.. Winamp and WMP play every song once before repeating a song.
With JITs Nexus skin I decided to give CF RC1 another try in my car. As indicated in another thread, RC1 is hella slow to start up. It also locks up a lot or does not properly switch away from an embedded app. It also starts without playing music sometimes and it sometimes stops music when switching to an embedded app (one that should not "pause"). It also still only truly browses by album and it still does not have a sort function for the now-playing list. ...but my biggest grip is that f***ing random is still broken.
1) Load all your music in to now-playing (about 8,000 songs for me)
2) Turn on random and press next-track a bunch.
3) Within less than 100 songs it will start repeating the same songs over and over.
Please consider my random implementation David. Take the now-playing array, randomize it, then play it in order. This guarantees that you will not hear the same song twice until you have listened to every song, or you have turned off random and then turned it back on again. It also allows you to move forward and backward in your random array with infinite history in both directions. This is how WMP works I believe. It is defiantly how the Kenwood Music Keg / PhatNoise PhatBox work and I really like it that way.
my destinator map resource down permanently
Are you reading this, David? I'm bringing back your customers LOL!Originally Posted by RPM_VR4
In all seriousness, you really should just implement random the way RPM describes, and move on. The whole random deisgn is pretty much flawed, I'm afraid.
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
It is implemented that way, so there must be a bug... It should not play a song again until it has played the entire playlist...
I will look for the bug, but I did implement it...
note: I did find one bug with random, but I thought I had it fixed in RC1...
david
