I read in the future releases you plan or hope to add more control for newer sound drivers. I was wondering if the current release supports the kx project drivers? When I try to adjust the rear or sub volume in the Mixer it doesn't work at all. I have a Soundblaster Audigy 2 with the kx project drivers installed and was wondering if I was not doing something correct or if my current setup is not supported at this time. Thanks for the help.
Ok thats what I read in another thread after I made this.. so would it be possible to change it from teh "Other" to "Playback" sections or should I just wait for the update?
If you can find a driver that moves them to the playback section, then it will work now... Otherwise wait until I add support for the Other section...Originally Posted by hornyleprechaun
david
Sounds great! Thanks for the quick responses at 3 AM!!! And thanks for such an awesome program!
