Results 11 to 20 of 27
Thread: New Release, Centrafuse RC2
  1. #11
    Jan 2004
    One more thing, the new shutdown menu is nice, but its odd that if yours using the shutdown menu, and press the exit program button, then it asks if you want to exit?
    This is only necessary when you dosen't use the shutdown menu.
  2. #12
    Variable Bitrate lazy_g's Avatar
    May 2005
    Netherlands (Bergen (NH))
    Quote Originally Posted by ShawJohn View Post
    Can we keep our old XML files then we don't have to keep re-doing the config and customisation works
    That i would like to know too...
    www.superchargedmiata.net - all about roadster lifestyle
  3. #13
    Apr 2005
    Dublin, Ireland
    Thanks David, h
    P4 Celeron 2.2 - 512MB - OPUS 250 - Audigy SE - BU353 - HQCT - No Speakers though :-(
  4. #14
    Jun 2005
    David, there is still a problem in the gps section when you try and search for an address using streets or citys. If you have streets called carnarvon close, carnarvon place or carnarvon drive you only get to see the first word in the address field on the left. If I search for carnarvon Close I see 7 carnarvon on the left???
  5. #15
    Jan 2006
    Illinois
    Anyone else having a problem finding the button to make videos full screen
    Jim
    2005 Acura TL
    2005 Honda VTX1800N
    PreludePC 2.0 in the making...
    Smaller, faster, better...
  6. #16
    Jun 2005
    Right I have tested this in the car and I have noticed the following.
    1) Speed still does not show correctly
    2) I used the same maps with RC1 and RC2 yet in RC2 I had some postcodes missing from the search
    3) Problem as discussed in the above post. This actually stops you using that kind of search for an address if there are more instances of the first part of the address
    4) Activating single click seems to behave like you are doubleclicking. Ie go to settings and click on the down arrow and instead of showing item 1/18 then 7/18, 13/18 and 18/18 it goes straight to 18/18. I even had it where it was double clicking on increase volume and even clicking on the eye icon in nav it then automatically clicked on shows turns.
    5) Orient North and orient forward seemed to be the wrong way round. Clicking on orient forward changed the map to show North at the top.
    6) Pausing the music for gps directions is too long for some voice prompts. Ie When it says "Turn Left in ....." Music will be paused for up to 3-4 secs more. I suggest instead of pausing the music but to lower the music volume like FD does, or even add it as an option to choose which you prefer.
    7) Street Name does not show anymore in the box which shows speed.
    Due to the following and more so with the gps not showing all postcodes like RC1 does I have had to uninstall and reinstall RC1. Also I have reproduced these errors/bugs on both my desktop and carpc.
  7. #17
    Jan 2006
    Illinois
    Wow... Double click 2x FTW.
    Im a DA.
    Jim
    2005 Acura TL
    2005 Honda VTX1800N
  8. #18
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    @ hatton920
    Sureley you could install RC2 and then copy the destinator stuff across from RC1
  9. #19
    VENDOR - Centrafuse veetid's Avatar
    Post any bugs you find here:
    Centrafuse RC2 Bugs
    david
  10. #20
    Jun 2005
    @ hatton920
    I did, that is what confuses me. Its exactly the same map but postcodes are missing.
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. New Release, Centrafuse RC1 (1.7)
    Last Post: 08-02-2006, 01:14 PM
  3. New Release Centrafuse 1.5
    Last Post: 11-02-2005, 01:48 PM
  4. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 04:13 AM
  5. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 10:17 AM
