Uninstall and reinstall worked for me...
I have reinstalled my computer, updated everything.
installed Microsoft.net Framework etc..
When i install CF it dont show any grahpic in the buttons anywhere.
Anyone have any ideas.....
Hi
I have reinstalled two times, but it wont help
STOP RIGHT THERE! Please compress your System / XML files and send them to fluxmedia support! They have been trying to resolve this bug.
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
The XML file should not be correct...Which languages have you selected?
Also please load and create the error, then email support the error.log file...
Also did you modify any language files? I did receive an email with some RC1 XML files that were from a system that had this problem, but they appeared fine...
I know this has to be creating an error.log, so please reload and email that file if you can...
david
Hi
I have reinstalled my pc again, i ran in too other problems also.
I turned out that i had got hand of a infected file somwhere.
I will try ti reinstall again i let you know how it goes.
Børge
Hi
This is the error log.
I have not modified anything in the files, exept from the resolution, but that was in the setup after install was done
__________________________________________________ ____
14.08.2006 17:09:31
Object reference not set to an instance of an object.
at centrafuse.main.runLaunchCommands(String section)
14.08.2006 17:09:52
at centrafuse.main.CF_localskinsetup()
14.08.2006 17:09:52
14.08.2006 17:09:53
Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.Collections.ArrayList.get_Item(Int32 index)
at centrafuse.Plugins.CFPlugin.CF_updateButtonText(St ring buttonName, String text)
14.08.2006 17:09:53
14.08.2006 17:09:53
14.08.2006 17:09:53
14.08.2006 17:09:53
14.08.2006 17:09:53
14.08.2006 17:09:53
at centrafuse.main.changeSkin()
14.08.2006 17:10:47
at centrafuse.Plugins.CFPlugin.CF_setPictureImage(Str ing pictureboxname, Image newimage)
14.08.2006 17:10:47
14.08.2006 17:11:07
I'm looking into this now...
david
