Important Notes
- all playback channels used for input, line-in, mic, cd-in, etc.. should be muted in the playback section of the mixer
- uninstall any previous versions of Centrafuse before installing the latest release
- after you setup your phone, restart the application before using it
- voice recognition requires a USB or Bluetooth microphone, or any separate input. Centrafuse uses the primary sound card input for sending data to the visualizations and adding pause/rewind/fastforward functionality to radio and satellite radio
New Features
- added the ability to enable/disable popups in web browser settings
- increased main title scroll speed
- added option to set the POI distance in navigation settings
- added avoid road support in navigation
- added a new beat sensitive visualization, removed two slower ones
- password fields are encrypted when saved
- added hotkeys for all dialogs, enter for ok/load, escape to cancel, and left/right to use arrows when available
- added show/hide POI categories on map in navigation by using + and - buttons (eye icon does not show back up when you reload the dialog, but +/- do work and hide/show POI's on the map, this will be fixed)
- all six native languages included English, French, German, Italian, Poruguese, and Spanish
- when run as shell is enabled all items in startup folders and registry run sections are executed, makes run as shell work with some installed devices
- added support for newer sound drivers rear/sub/center channels
- rear and sub channels change volume with the master based on a ratio you set in the mixer as you adjust the sliders
- added feature to allow master volume controls to adjust pre channel
- external applications can now be set as non-GUI external applications and not embed within the application
- you can specify which output channel to send music with a multi-channel soundcard
- added web links which add a button to the main page that load the web browser with a specified URL, custom icons supported like external applications
- added hotkey for toggling fullscreen mode, same hotkey works on all sections that support fullscreen
- added hotkeys for navigation functions cancel current route, zoom in/out, load navigation menu, load view menu
- added getGPSInfo function to the SDK which includes altitude, azimuth, direction, eta, etr, housenumber, latitude, lockedsatellites, longitude, remainingdistance, speed, street, city, zip, destination city, destination house number, destination latitude, destination longitude, destination street, and destination zip
- added CF_setGPSRoute function to the SDK which allows you to route to a location using latitude and longitude
- added function to CF_setGPSRoute in the SDK which allows you to route to a location using city or zip and street, housenumber is optional
- all files and directories are properly sorted, including when loaded from CD/USB devices
- added option to disable tag reading when inserting CD/USB devices and browsing by music folders, it speeds up the loading and browsing when in these modes
- added x,y coordinates to the config.xml file, which allow you to position the application anywhere on the screen(s), this will be adjustable through settings in the next release
- added a standard size picture box for full screen visualization album art view
Bugs Fixed
- phone and the phone wizard properly run
- show turn function in navigation shows the selected turn
- speed in navigation should display properly
- turn by turn distance in navigation, in imperial mode, displays properly
- the right turn by turn images are displayed for left hand and right hand side driving
- orient north/forward button in navigation view dialog is no longer backwards
- turn by turn buttons in navigation work with keyboard control
- decreased the amount of time the audio pauses when directions are spoken in navigation
- VFD setup screen has the proper heading
- quickest route/shortest route toggle properly works when not in a current route
- enter works on the list views in single or double click mode
- keyboard control works on list views when in single click mode
- play now button properly works in single click mode in "My Library"
- buttons should no longer stick in single or double click mode
- changing skins while you have a picture list loaded in media properly updates media background
- fixed holding down the back button in global navigation to go back to the previous section
- space in OSK only enters one space
- using enter key on some list views no longer sends the enter stroke twice
- plugins and external applications can be removed while in single click mode
- when external application settings change, they will be shown without reloading settings
- bug fixed with visualizations not being "beat sensitivity"
- navigation address search works with both capital and lower case letters, when using a keyboard
- web browser will continue to work after you leave and go to another section and come back
- web browser display problem fixed
- web browser works with popups, if the popup is closed with a button on the web page, the browser goes back
- when you change the skin and then watch fullscreen video, when you hit next video it will stay fullscreen
- fixed corrupt database problem where initial setup runs everytime and the buttons show no text
- navigation quickest route/shortest route display issue fixed
- when you close TV the previous audio starts playing again
- cdrom and usb devices should be properly detected, not using wmi anymore
- TV settings save when you exit the application
- holding down on volume controls with keyboard properly functions
- letters do not appear ontop of list views when they are not suppose too
- menu button does not stay highlighted when clicked to close the menu
- navigation does not pause music when you have no voice prompts or voice prompts disabled
- street name shows up in navigation information display bar
- improved method of closing external applications, all applications should not properly exit
- fixed visual notifications in navigation routing
- phone signal does not show full signal when there is no signal, although some phones send invalid data when no signal present
- full control of the application is works while fullscreen visualization is playing on a secondary secreen
- mini media player visualization updates while fullscreen visualization is playing on a secondary screen
- negative speed no longer comes back in navigation mode
- mouse cursor hides on resume from hibernation and standby when enabled
- bug fixed where entering a favorite in navigation with a blank name caused you to never be able to remove it
- fixed bug where some GPS receivers did not stay locked onto satellites in navigation mode
- when making outgoing calls the accept/hang up dialog pops and does not disappear
- when searching using the navigation address search screen, the C & D buttons now work
- GUI application parameter for external applications properly gets saved
- you are able to add an external application in single click mode
- window name is not required when setting up a non-GUI external application
- list items highlight when clicked in single click mode
- video icon is properly displayed when toggling the favorites button on the media player while playing a video
- you can click anywhere outside the loading screen and it will disappear, this if for if you don't want to see it or it gets stuck loading a web page
- when searching the library by clicking on the top title header, it properly displays if you were previously in picture mode
- you no longer get stuck in a search when you click the top title header, you can simply press library to get back to your library
- when moving through multiple HD playlists with one of them being a picture playlist, the audio will not stop
- in settings the text no longer goes too far to the right on the labels on the left
- back now goes to the previous section and does not count the main screen as a section
- all picture thumbnails properly get created
- web browser favorites work in single click mode
- in search mode play now properly works, when in single click mode
- when you change screens the main title header properly displays the "...", when necessary
david
