Results 1 to 9 of 9
Thread: Usb Gps
    Newbie TEC_Ghost's Avatar
    Jul 2005
    Kansas
    Usb Gps
    Hey, Ive got a USB GPS made by Garmin GPS18 model, and Ive noticed only COM1 shows up on the GPS adapter setup and no USB port's. Is there something Im doing wrong or does CF not incorporate USB yet?
    VMS
    VMS is offline
    Low Bitrate VMS's Avatar
    Apr 2006
    CF can use usb gps, go under settings and see which port your GPS is. Then chose this port in CF. Should work!
    Vehicle Media Systems
    Australia Car PCs www.vmscarpc.com.au
    Slovenia (EU)
    Garmin GPS uses his own system. It doesn't use neather NMEA nor SIRF, so it is only compatible with Garmin SW and vice versa.
    Actually you can use an interface, that converts the protocol from Garmin to NMEA or SIRF. Search for GPSGate or GPSProxy.
    Nov 2005
    Quote Originally Posted by stric View Post
    Does this enable the use of the software that comes with for example streetpilot gps´s (Mapsource) and use it stand alone inside a front end or does it just enable the use of a garmin gps to be used with the pc?
    Black SolarCell Portable Bluetooth Gps reciever for sale, Contact me!
    BMW E46 320 Touring project thread, making the perfect multimedia car ;)
    BMW E46 WORKLOG
    Slovenia (EU)
    I think it does for Mapsource too. I am sure it does work nRoute (also Garmin software) with normal SIRFIII GPS.
    Jul 2005
    Kansas
    Woot Got it to work, what it does is it setsup virtual COM ports Com3 Com4 Com5 all feeding off of the USB GPS so you can use it with any GPS program and at the same time Multiple programs. Thanks guys!
    Car: 2003 Chevy Cavalier
    Cpu: 800mhz, 512mb ram, 133mhz fsb, 40gig hd.
    Install Progress[|||||||||||||||||||||||||] 95%
    Fixing Sound System
    Elsewhere
    Quote Originally Posted by bimmerpc View Post
    The garmin GPS18 will output NMEA.
    How to enabl that, I don't know, sinc eI don't have one. Maybe the manual will tell you...
    How about the Wiki?
    Nov 2005
    Maybe a silly question but I´ve seen threads about tomtom emulators but not garmin. I mean the touchscreen software that is very user friendly runs from inside my garmin streetpilot. If I install the software cd that comes with the gps on my pc I dont get anything that I can navigate with (just a route planner). So how do I manage to use the streetpilot´s software from my pc?
    BMW E46 WORKLOG
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    You can't. I think the reason you can have TomTom emulators is that they released the TomTom software for either palm or pocketpc. Garmin's software is totally proprietary and won't run on anything but Garmin hardware. I don't think you can even get a copy of the software on CD, let alone run it on any sort of PC.
  1. garmin mapsource and usb gps mouse
    By thecrow in forum GPS
    Last Post: 09-26-2006, 03:24 PM
  2. Replies: 9
    Last Post: 12-08-2004, 09:48 AM
  3. earthmate usb gps with MS Streets&Trips?
    By liquid_smoke in forum GPS
    Last Post: 11-27-2004, 09:45 PM
  4. D3 with USB GPS after HIBERNATION
    By BOND007BE in forum Map Monkey
    Last Post: 11-26-2004, 02:54 PM
  5. FS: Group Buy USB GPS Receiver (BU-303)
    By Toups in forum Classified Archive
    Last Post: 03-15-2004, 07:32 PM
