I'm suddenly having problems with hibernation in RC2.
I have been successfully hibernating and resuming RC2 since it came out. The only real problem I had with RC2 was using XM with the XMPCR. For some reason all the channels would not load properly. On a whim, I unplugged the XMPCR from the USB hub it was using and plugged it into a USB port on the computer. Voila, all of the XM channels loaded perfectly. I figured my problems were solved; however, when I later resumed from hibernation CF came back locked up. None of the buttons would work. My only option was to reboot the computer. I tried hibernating and resuming several more times and each time CF would come back locked-up.
I then plugged the XMPCR back into the hub where it previously had been, rebooted, loaded CF, hibernated and resumed. Same problem with CF lock-up.
To make sure it was a CF issue and not an XMPCR issue I loaded RoadRunner. I then hibernated and resumed and everything, including XM, worked perfectly, indicating that it's a CF issue.
Anybody have any thoughts on this?
