That's odd... anyone else have this problem? I cannot reproduce anything like this... This generally is caused by an old install, which will not be a problem going forward with all the RC releases....
david
I've downloaded the latest version on the website, installed it on a clean install and used the license key on the site but it exits with an invalid license alert. I tried numerous times reinstalling, erasing the centrafuse folder and still no go. Any idea how I can fix this?
david
Are you absolutely sure you are using the corresponding RC2 license file?
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
Ok, I just tried the code in another PC, and it worked. So what's wrong with my real carputer setup that isn't getting uninstalled? Where else in the system does centrafuse install anything other than the Flux Media folder in Program files?
The very first time I installed Centrafuse in the carputer last night, centrafuse worked but when I tried to enter the code, it started giving an invalid license alert and it never worked again even after reinstalls.
I'm sorry, I meant to make sure you were using the correct license number, for that version
2002 Honda CR-V
I'm sorry, probably only David can help you with this one. No one else really knows how the serial number validation scheme works, and I suspects your computer thinks the SN is not valid for some reason.
Did you attempt to change the computer's date at some point? It is a known issue with CF, where if you change the date for any reason, it will crap out on you and never work againOK, I'm exaggerating, but it pretty much will refuse to work unless you clean up your system by doing the rain dance...
2002 Honda CR-V
Oh no, I think I did update my time in the middle of things.
Anyway, thanks for trying to help. I'll try to fix this still, I'll post it here if I get anywhere.
That would do it... I think it brings people more headaches than Flux would ever want!![]()
2002 Honda CR-V
