Results 1 to 3 of 3
Thread: RC3 PhoneControl error
    Sep 2005
    I got the same error using RC2..
    I start the PhoneControl setup wizard, search for my phone, and detech it. Then the wizard wants to search for ports on my phone, and i get this error when clicking "Start":
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.NullReferenceException: Object reference not set to an instance of an object.
    at PhoneCtlWizard.Form1.FindSerialPortMS()
    at PhoneCtlWizard.Form1.btnScanPort_Click(Object sender, EventArgs e)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ButtonBase.WndProc(Message& m)
    at System.Windows.Forms.Button.WndProc(Message& m)
    at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
    at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    PhoneCtlWizard
    Assembly Version: 1.7.2.11770
    Win32 Version: 1.7.2.11770
    CodeBase: file:///C:/Programfiler/Flux%20Media/Centrafuse/PhoneControl.NET/PhoneCtlWizard.exe
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    System.Data
    CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
    zBTHelper
    Assembly Version: 1.0.1.19907
    Win32 Version: 1.0.1.19907
    CodeBase: file:///C:/Programfiler/Flux%20Media/Centrafuse/PhoneControl.NET/zBTHelper.DLL
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    Infragistics.Win.v3.1
    Assembly Version: 3.1.20041.15
    Win32 Version: 3.1.20041.15
    CodeBase: file:///C:/Programfiler/Flux%20Media/Centrafuse/PhoneControl.NET/Infragistics.Win.v3.1.DLL
    Infragistics.Shared.v3.1
    CodeBase: file:///C:/Programfiler/Flux%20Media/Centrafuse/PhoneControl.NET/Infragistics.Shared.v3.1.DLL
    Infragistics.Win.UltraWinTabControl.v3.1
    CodeBase: file:///C:/Programfiler/Flux%20Media/Centrafuse/PhoneControl.NET/Infragistics.Win.UltraWinTabControl.v3.1.DLL
    Infragistics.Win.Misc.v3.1
    CodeBase: file:///C:/Programfiler/Flux%20Media/Centrafuse/PhoneControl.NET/Infragistics.Win.Misc.v3.1.DLL
    OpenNETCF.Net.Bluetooth
    Assembly Version: 1.4.50709.0
    Win32 Version: 1.4.50709.0
    CodeBase: file:///C:/Programfiler/Flux%20Media/Centrafuse/PhoneControl.NET/OpenNETCF.Net.Bluetooth.DLL
    OpenNETCF.Desktop.Communication
    Assembly Version: 2.8.2375.24228
    Win32 Version: 2.8.2375.24228
    CodeBase: file:///C:/Programfiler/Flux%20Media/Centrafuse/PhoneControl.NET/OpenNETCF.Desktop.Communication.DLL
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
    VENDOR - Centrafuse veetid's Avatar
    I will look into this...
    david
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Quote Originally Posted by proximo View Post
    When using the Microsoft Bluetooth driver, you have to make sure that you have let the driver discover the services of your phone after pairing. Otherwise the PC is paired with your phone but it won't have any services (such as COM ports) assigned. In such case the Wizard won't be able to find anything.
    The only thing that concerns me is that it's not supposed to lead to an exception.
    Skinning to go... VisualDesigner2!
  1. Headunit (Linux/Windows CarPC frontend) + initial screenshots
    By NoPistonPC in forum Other Cool Front Ends
    Last Post: 08-24-2007, 03:57 PM
  2. Need help with phonecontrol error on start up
    By DaveTN in forum PhoneControl
    Last Post: 11-20-2005, 01:58 PM
  3. Replies: 7
    Last Post: 07-01-2005, 04:29 PM
  4. Error launching PhoneControl
    By wolf041 in forum PhoneControl
    Last Post: 01-18-2005, 04:21 AM
  5. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
