Results 1 to 10 of 10
Thread: Phonecontrol gets stuck at scaning ports...
    Apr 2006
    Question Phonecontrol gets stuck at scaning ports...
    When running the setup.. everything works fine untill it says the "start to scan the ports" It just get stuck there. I ran phonecontrol test and tested port 4 which is my bluetooth and everything worked fine. I tried to manuallu set the port to 4. That works but when I tried to use the phone in centrafuse it says it still has to be configed.. but when i config it it just gets stuck on scaning for ports. I am using MS BT drivers. Everything is already paired. The services are already enabled. Any ideas?
    Constant Bitrate 2 STanGeR's Avatar
    Aug 2005
    Terre Haute, IN
    Same problem with me. It tells me that it can't find my port, but it sees my device. The PhonecontrolTest sees my Com 4 as well. I am using the WidComm drivers.
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    I've put version 1.7.4 online today. This mainly shold have ironed out the bug with not copying the WM5 driver but I also changed a portion of the port search.
    You may download the patch and extract it into the PhoneControl.NET folder within the CF folder.
    Skinning to go... VisualDesigner2!
    Jun 2006
    Hi zorro,
    I'm facing a similar problem.
    Everything was working properly on CF1.6
    Now, everytime that include the phonecontrol feature, my computer freezes and hardly responds. I uninstalled RC3 and reinstalled CF1.6 to see if it gets back to normal, but faced a license problem.
    I then went to Phonecontrol folder and ran PhonecontrolTest using the same old "port", it worked properly and here is what i got.
    Code:
    [~~~~~~~~~~~~~~~~~~~~~~START~~~~~~~~~~~~~~~~~~~~~~~~~]
    ATE0
    ATE0
    OK
    ATI0
    Sony Ericsson K750
    OK
    ATI1
    CXC125952
    OK
    ATI2
    OK
    ATI3
    Sony Ericsson 750 Bluetooth Modem
    OK
    ATI4
    OK
    ATI5
    Configuration Settings on Channel 0
    &C: 1
    &D: 0
    *EIAC: 1,1,"MMS"
    *EIAC: 1,2,"Idm"
    *ELIN: 1
    +CBST: 0,0,1
    +CDIP: 0,0
    +CGACT: 1, 0
    +CGATT: 1
    CGCLASS: "B"
    +CGDCONT: 1,"IP","mms.m.com.","0.0.0.0",0,0
    +CGEQMIN: 1,3,0,0,0,0,0,0,"0E0","0E0",2,0,0
    +CGEQREQ: 1,4,0,0,0,0,2,0,"1E4","1E5",0,0,0
    +CGEREP: 0,0
    +CGQMIN: 1,0,0,0,0,0
    +CGQREQ: 1,0,0,3,0,0
    +CGREG: 0,1
    +CHSN: 0,1,0,12
    +CHSR: 0
    +CHSU: 0
    +CMEE: 0
    +CMUX: 0,0,1,31,10,3,30,10,2
    +CR: 0
    +CRC: 0
    +CRLP: 61,61,48,6,0
    +CRLP: 120,120,48,6,2,3
    +CSCS: "GSM"
    +CV120: 1,1,1,0,0,0
    +CVHU: 2
    +DR: 0
    +DS: 3,0,1024,32
    +ICF: 3,3
    +IFC: 2,2
    +ILRR: 0
    +IPR: 0
    E: 0
    M: 0
    Q: 0
    S0: 000
    S10: 002
    S2: 043
    S3: 013
    S4: 010
    S5: 008
    S6: 002
    S7: 050
    S8: 002
    V: 1
    X: 4
    OK
    ATI6
    OK
    ATI7
     Modem Configuration Profile
    Product Type       Terminal Adapter
    Interfaces         Bluetooth, IrDA, RS-232, USB
    Options            OBEX, PPP, RLP, V42bis
    OK
    AT+GMM
    Sony Ericsson K750
    OK
    AT+GMR
    R1BC002
    OK
    AT+CHUP=?
    OK
    AT+CSCS=?
    +CSCS: ("GSM","IRA","8859-1","UTF-8","UCS2")
    OK
    AT+CSCS?
    +CSCS: "GSM"
    OK
    AT+CRC=?
    +CRC: (0-1)
    OK
    AT+CRC?
    +CRC: 0
    OK
    AT+CLIP=?
    +CLIP: (0-1)
    OK
    AT+CLIP?
    +CLIP: 0,1
    OK
    AT+CNMI=?
    +CNMI: (2),(0,1,3),(0,2),(0,1),(0)
    OK
    AT+CNMI?
    +CNMI: 2,0,0,0,0
    OK
    AT+CMER=?
    +CMER: (0,3),(0,2),0,(0-1),0
    OK
    AT+CMER?
    +CMER: 0,0,0,0,0
    OK
    AT+CMER=3,2
    OK
    AT+CGMI=?
    OK
    AT+CGMI
    Sony Ericsson
    OK
    AT+CGMM=?
    OK
    AT+CGMM
    AAB-1022011-BV
    OK
    AT+CBC=?
    +CBC: (0-2),(0-100)
    OK
    AT+CBC
    +CBC: 0, 80
    OK
    AT+CSQ=?
    +CSQ: (0-31,99),(0-7,99)
    OK
    AT+CSQ
    +CSQ: 8,99
    OK
    AT+CPBS=?
    +CPBS: ("ME","SM","DC","LD","FD","MC","MV","RC","HP","BC")
    OK
    AT+CPBS?
    +CPBS: "ME"
    OK
    AT+CPBS="SM"
    OK
    AT+CPBS="ME"
    OK
    AT+CPBS="MC"
    OK
    AT+CPBS="RC"
    OK
    AT+CPBS="DC"
    OK
    AT+CPBS="MT"
    ERROR
    AT+CPBS="EN"
    ERROR
    AT+CPBS="ON"
    ERROR
    AT+CPBS="AD"
    ERROR
    AT+CPBR=?
    +CPBR: (1-30),80,180
    OK
    AT+CPBR=1,1
    +CPBR: 1,"03704205",129,"","2006/09/21,17:43"
    OK
    AT+CKPD=?
    OK
    AT+CKPD?
    ERROR
    AT+CLCC=?
    OK
    AT+CLCC?
    ERROR
    AT+CPAS=?
    +CPAS: (0,3,4)
    OK
    AT+CPAS
    +CPAS: 0
    OK
    AT+CPMS=?
    +CPMS: ("ME","SM"),("ME","SM"),("ME","SM")
    OK
    AT+CPMS?
    +CPMS: "SM",10,10,"SM",10,10,"ME",183,187
    OK
    AT+CMGR=?
    OK
    AT+CMGL=?
    +CMGL: (0-4)
    OK
    AT+CMGF=?
    +CMGF: (0)
    OK
    AT+CMGF?
    +CMGF: 0
    OK
    AT+CPIN=?
    +CPIN: (READY,SIM PIN,SIM PUK,SIM PIN2,SIM PUK2,PH-SIM PIN,PH-NET PIN,PH-NETSUB PIN,PH-SP PIN,PH-CORP PIN,PH-ESL PIN,PH-SIMLOCK PIN,BLOCKED)
    OK
    AT+CPIN?
    +CPIN: READY
    OK
    AT+CUSD=?
    +CUSD: (0-2)
    OK
    AT+CUSD?
    +CUSD: 0
    OK
    AT+CLCK=?
    +CLCK: ("CS","PS","SC","P2","AO","OI","OX","AI","IR","AB","AG","AC","FD","PN","PU","PP","PC")
    OK
    AT+CLCK?
    ERROR
    AT+CIND=?
    +CIND: ("battchg",(0-5)),("signal",(0-5)),("batterywarning",(0-1)),("chargerconnected",(0-1)),("service",(0-1)),("sounder",(0-1)),("message",(0-1)),("call",(0-1)),("roam",(0-1)),("callsetup",(0-3))
    OK
    AT+CIND?
    +CIND: 4,3,0,0,1,0,0,0,0,0
    OK
    AT+COPS=?
    *** Timeout ***
    AT+COPS?
    OK
    [~~~~~~~~~~~~~~~~~~~~~~~END~~~~~~~~~~~~~~~~~~~~~~~~~~]
    When I run the same test on RC1 and RC3, the response is always "Timeout", the computer freezes and I can only turn it off with a hard shutdown.
    I'm using a Edimax Class 1 adapter V2.0 with Toshiba drivers with a SE k750i
    Thank you
    Mar 2004
    Munich, Germany
    Quote Originally Posted by SUVputer View Post
    Hi zorro,
    Thank you
    Well, in some way it makes sense: 1.6 has used another communication control but that one was the reason for many problems. Since 1.7 I've replaced it there were no such problems at all.
    I've heard once that the Toshiba drivers can cause such behaviour but I'm not sure this is for real.
    Do you have the option of testing it on another computer/BT stack?
    Apr 2006
    yea.. 1.6 is the only version that has ever worked for me for CF also..
    Jun 2006
    Quote Originally Posted by zorro View Post
    I will check that and let you know..
    Aug 2005
    Plano/College Station, TX
    I had this problem that it wouldn't scan the proper port through phone control. This happened when I already had a bluetooth connection open with my phone. If I disconnected whatever connection was open then phonecontrol could find my phone and the proper com port just fine.
    Apr 2006
    nope new patch dosent work
    Mar 2004
    Munich, Germany
    Ok, you have two options to get a workaround:
    1. Skip the BT scan and pick any one of the COM ports listed in the next page. Then, after the Wizard has finished use the Extended Configurator to correct the port number.
    2. If you applied the changes with the Extended Configurator already, create a new file named "wizard" (w/o extension, file size doesn't matter) within the PhoneControl.NET folder.
  1. Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 04-22-2012, 06:03 PM
  2. Phonecontrol and Motorola v3
    By kyrenia in forum PhoneControl
    Last Post: 06-07-2007, 09:49 AM
  3. unhidding PhoneControl from FrodoPlayer
    By larios in forum FrodoPlayer
    Last Post: 03-17-2007, 07:52 AM
  4. Usb ports on Morex Case problem
    By volum3rider in forum General Hardware Discussion
    Last Post: 11-14-2005, 06:25 PM
  5. PhoneControl embedded in Mediacar?
    By _wd in forum MediaCar
    Last Post: 11-18-2004, 04:57 AM
