Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: RC3 Sound QUality
    Raw Wave justintime's Avatar
    Apr 2005
    RC3 Sound QUality
    I have upgraded my CarPC to v 1.7RC3, from the good old v 1.4
    So this is the first time I have the ability make some sound quality comparisons between the old and the new. Keep in mind I have used 1.4 for about 1 year in my car, and I know very well how it sounds with my equipment. I know sound percpetion is subjective, but I have a very good reference point.
    I notice that sound quality is definitely different in RC3. I am using exact same settings as before: Flat EQ, No normalization, and volume levels are set to same (main and pre).
    I would say that in 1.4 the bass response was better. It was richer, chest punding base where it mattered. I can't get that anymore with RC3, and I don't know why. Fiddling with the EQ helped a little for some albums, but then made other albums worse.
    David, has the Sound processing changed since 1.4? In what way?
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by justintime View Post
    It shouldn't have... I have gotten nothing but people saying the sound has improved from 1.4...
    david
    _
    Mar 2004
    Little Elm, Texas
    check your install. Something might have changed on the audio side of things. Amplifiers, speakers, connections, grounds, power, speaker wire, etc.
    Jan Bennett
    May 2006
    Seattleish, WA
    Quote Originally Posted by RedGTiVR6 View Post
    ??? Justin's been around here a LONG time, and given that he says he JUST upgraded to RC3, then I'll bet that he didn't also swap head units and re-wire the car while waiting for the install to complete.
    Hey Justin (and David)... I think I agree with you. I've been having issues with CF's embedded XM support, so I just switched back to AIMEE. There is a DEFINITE difference in how AIMEE sounds versus CF - like you say, the bass response is tighter outside of CF. There are obviously a couple of variables there, but given that the source is constant, I have to point and say it's the difference between the internal & external XM apps.
    :: Mark
    Apr 2005
    Correct, I ONLY CHANGED the CF app!
    2002 Honda CR-V
    _
    Mar 2004
    Little Elm, Texas
    installs change over time, wires come loose and move. Connections rust and corrode.
    Doesn't matter if it's worked great for 10 years. Things happen, ESPECIALLY in a car environment.
    Jan Bennett
    Jan 2004
    I think that the sound quality in rc3 is way better than rc2!
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    yes, but he's comparing the sound to what it was right before the install of RC3
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    May 2006
    Seattleish, WA
    Quote Originally Posted by clemen View Post
    I agree that it's "better" in RC3 than 2, but listen to some audio files or XM _outside_ of CF (i.e., use MediaPlayer) and compare those two states.
    The bass response difference in XM outside of CF is significant enough that I had to turn down my subwoofer.
    :: Mark
    Raw Wave lostreception's Avatar
    NY
    Quote Originally Posted by Quattro View Post
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  1. Replies: 33
    Last Post: 09-01-2005, 05:14 PM
  2. XM Radio Sound Quality - What Happened?
    By tbird2340 in forum FrodoPlayer
    Last Post: 07-14-2005, 06:59 PM
  3. Super Sound Quality
    By DK888 in forum General Hardware Discussion
    Last Post: 04-01-2005, 11:45 AM
  4. XM Sound Quality?
    By nFiniteTuning in forum General MP3Car Discussion
    Last Post: 01-29-2005, 12:20 PM
  5. quality sound cards for carputer?
    By tdevil in forum Car Audio
    Last Post: 06-05-2004, 05:02 PM
